Bryston Pre+Power set or Integrated B100??
0 Members and 1 Guest are viewing this topic. Read 1986 times.
« on: 17 Jan 2010, 01:33 am »
Hi,
Wonder IF there is a general concordance about it:
>> What is the best sound Bryston preamp to use with the 2BSST2 or 3BSST2 ??
>> Or best sound is a integrated B100??
The interconnect is the Kimber KCAG.
Thanks for yours input.  Gustavo
Daniel Datchev
Re: Bryston Pre+Power set or Integrated B100??
« Reply #1 on: 17 Jan 2010, 07:46 am »
Hi,
Gustavo
to my piont of view the better option is using the XLR connection which is not presented in B-100.
There is another option using B-100 both as pre-amp and power amp and have a second 2B-SST for bi-amping.
Daniel
« Reply #2 on: 17 Jan 2010, 07:52 am »
Hello Daniel,
You are mean say the Bryston amps/pre have better sound with balanced connection??
Daniel Datchev
« Reply #3 on: 17 Jan 2010, 08:22 am »
Hi Gustavo,
as I have already bought B-100 I had to place a audio ground transformer to isolate the common ground current between BCD-1 and B-100. Now is much better and the amplifier controls the speakers easier. Many friends have told me not to do this, but to my ears this is a better sound. If I had to buy now | would choose XLR connection units. In the Jensen Transformers there is explanation about audio connections.  http://www.jensen-transformers.com/iso_aud.html
Have a read and will understand what I mean.
Daniel
« Reply #4 on: 17 Jan 2010, 10:47 pm »
Thanks for the link. I happy it works for you.
Maybe I misunderstand your post, looks a too big transformer for audio/music signal, I assuming you are using this transformers in electrical mains wall outlet as filter etc...
I have a unsuccesfull experience with balanced transformers, I already use a 5kg 300W Toroidal transformer to down 220V to 120V for my SCD-1 power feed, for some 5-6years, but when I remove the transformer and started use a direct 120V outlet the afew month ago, I have a huge gain in sound quality.
So I realize my condo Transformer is a big 225KVA with 13.8KVolts input and my Toroidal just 300Watts with 220V input.
Regards, Gustavo
Daniel Datchev
« Reply #5 on: 17 Jan 2010, 11:21 pm »
Hi Gustavo,
the link is for interconnects isolation, nothing to do with mains.
Daniel
« Reply #6 on: 17 Jan 2010, 11:48 pm »
Hi Gustavo,
Daniel
I see, Thanks for clear.   My other hypothesis for this devide was it could transform a unbal connection in balanced.
Do you have try aluminium tape to passively isolate the cabe??
Re: Bryston Pre+Power set or Integrated B100??(Help Mr.Tanner)
« Reply #7 on: 21 Jan 2010, 03:00 am »
Hi,
Hi Mr.Tanner,
Iam question you again.   Could you give some light on these doubts above??
Thankyou for you time and patience.  Gustavo
P.S.: If you have no opinion there is no problem, I thank you anyway.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #8 on: 21 Jan 2010, 12:21 pm »
Hi Mr.Tanner,
H Gustavo,
When we design our integrated amps we do not compromise the performance. In fact we use the exact same parts just on one chassis rather than two.  So I think it is more a choice of packaging rather than performance.
james
« Reply #9 on: 21 Jan 2010, 01:35 pm »
H Gustavo,
james
OH, I understand!  Thankyou for your direction,  Gustavo
