Song Center size
0 Members and 1 Guest are viewing this topic. Read 1917 times.
divisionbell77
Song Center size
« on: 16 Jan 2010, 09:09 pm »
Don't see it on the website(or completely missed it).  Can someone give me the size?  I am thinking I will have to lift the TV a half inch or two to fit under it, just need to know how much higher.
Thanks in advance.
srb
Re: Song Center size
« Reply #1 on: 16 Jan 2010, 09:27 pm »
Don't see it [SongCenter size] on the website(or completely missed it).  Can someone give me the size?
No you didn't miss it.
Jim, while I am complimenting your website in another thread, there is only a Specifications page for the SongTower QWT, but none for SongCenter, SongSurround or SongSub!
metier
« Reply #2 on: 16 Jan 2010, 10:02 pm »
Thanks in advance.
Just measured mine width 18" depth 11.5" height 8"
Here is from an old page
Model
SongCenter
(2-way center channel)
  Design  MTM 2-way
  Drivers  (1) Hiquphon OW2 tweeter, (2) Seas CA15RLY midwoofers
  Response  52Hz - 20KHz (+/- 3db)
in ported cabinet
  Sensitivity
(dB/2.83v/1M)
88db
  Impedance
(nominal)
4 ohms nominal
  Recommended Amplification  30 - 150 tube watts
80 -250 solid state watts
  Box Alignment  Sealed or ported as desired
  Dimensions
(HWD)  8" H x 18" W x 11.5" D
Pat
jsalk
« Reply #3 on: 17 Jan 2010, 04:10 am »
Steve -
You are correct.  Actually, there are quite a few things I would like to add to the web site, but there are only so many hours in the day.  I am trying to add a little every day now and that is one of the things on my list.
- Jim
atroder
« Reply #4 on: 18 Jan 2010, 04:02 am »
OK, I have a SongCenter on order and took a close look at these specs and saw the 4 ohm nominal impedance. I am going to drive the center and surrounds with a Pioneer VSX-21 rated at 110W/channel at 8 ohms. Now the surrounds I have are 8 ohms, the SongCenter is 4 ohms, but the VSX-21 only has a single speaker setting at either 8 ohms or 6 ohms. This setting is not on a per speaker basis. That leaves me a little mystified as to how to configure the VSX-21 - 8 or 6 ohms. Can someone please shed some light on this? Thanks!
srb
« Reply #5 on: 18 Jan 2010, 05:17 am »
Normally receivers that have a speaker impedance switch employ it as a current limiter so that the receiver will not overheat if the impedance gets too low.  However, dynamic range can be reduced with this current limiting in effect (6 Ohm position).
I usually recommend (and especially since you are using the receiver only to drive the 4 Ohm center and a pair of 8 Ohm surrounds) that the switch be left on the 8 Ohm setting, and that you monitor the heat produced by the receiver.
If it doesn't feel like it's running too hot, leave it at the 8 Ohm position, but if it seems like it is running too hot, switch it to the 6 Ohm position to reduce the possibility of overheating.
atroder
« Reply #6 on: 18 Jan 2010, 02:46 pm »
Steve - thanks, man - sounds perfectly reasonable.
