0 Members and 6 Guests are viewing this topic. Read 1220963 times.
would be grateful if some could help me quickly. Does it matter if the wire to the speaker binding posts are close to the torroidal transformer inside the amp case.
the toroids and the speaker wire will be in different boxes. Only they will have a 12mm wood ply between them. A a situation might occur that the speaker wire might be going right over the core of the transformer.( though I can easily avoid it)So was thinking if the magnetic feild of the transformer will affect the speaker wire.Also I could line the transformer box will aluminium foil and connect it to earth. Would that help ?
Hey there I have the SDS-254 which i am building for these http://www.audioheuristics.org/projects_gallery/ER18DXT/ER18DXT.htm#I am now adding another speaker as the center channel and need a mono amp to drive it. Which series would you recommend? Tom said I could use either the CDA254 or SDS254 in bridged mode.
Thanks krikor that's a lot of money for a mono amp oh well
How do you wire the classD amp remote? It is probably somewhere in this post but being a computer idiot I have almost never been able to find anything using the search function .The way I wired it was obviously wrong because all I got was smoke and fire , thankfully it was only the remote wire that burned not the amp which is still working. Thanks, Mike
Thanks for advice on using print and browser search function, but you missed the computer idiot comment I made, how do you do a browser search
Thanks srb for computer info, but still can't find anything on how to wire a remote on off switch.
