0 Members and 6 Guests are viewing this topic. Read 1220961 times.
Relax. Tom is a man of very few words.
SMPS800R for FL/FR channel and SMPS500R for the rest. My initial design is using a single SMSP2000R but Christi from Connex advice that one power supply with each board is a better design. In the future, if I go for 11 channels, will consider building another 3 channel power amp using nCore 400. The review so far look interesting but far more expensive than ClassDAudio. Each channel would cost around USD 800 while ClassDAudio is 2 channels around USD 360 - 1 channel = USD 180.
Hi. Since he is not replying me after such a long period, any advice you can offer me?Thanks
toooootally worth it.
Try [email protected]. I had no problem getting a reply from him last 2 weeks.
call on the phone?
I had no problem getting a response from Tom yesterday. Also found out that the IRS module is inverted amp when running in stereo mode. If you use it with Audyssey, the phase warning will pop out. Just reverse the polarity for speaker output. No problem if you only run with 2 speakers without a sub.
