0 Members and 5 Guests are viewing this topic. Read 1220064 times.
When you get it all going, let us know if you think this setup is superior to the Class D audio heavy duty power board. Thanks!
I have already assembled a SDS258 amp kit. Everything is going on fine. I am thinking of adding another amp board for additional 2 channels to power the surround. As this is for the surround only, I do not really need the 258. Is it OK to buy the cheapest amp from Class D audio to tap on the power supply from the SDS258 kit?
Anyone? Can I, for example, add a CDA224 amp to the SDS258 kit to build a 4 channel power amp?
You sure can! Heck, my case will take those two boards.
Thanks! I just want to make sure that the power supply will not go bonkers, powering two different types of amp.
+1 On jt"s case, I was able to mount the above ps board in his casejust had to angle it to line up two holes, did not have to drill any,easy as pie.
Just finished the kit with the ti-600. Another +1 on the case. I am so happy with the sound I ordered another amp to make it a dual-mono. I want to revise some of my connections and wire pathways, too, and I'll post pics when that's all done.
Hi all,After reading through half these threads, I'm interested in picking a CDA254 kit to drive a set of 4ohms Natalie P. I currently have the Onkyo RC180 which does 110w/ch x 7 and it does have pre-outs. If I were to pick up the cDA254 kit, would I still need to look for a pre-amp, or would the RC180 be adequate enough? thanks
