$175 Class D amp--120 wpc
0 Members and 7 Guests are viewing this topic. Read 1206013 times.
praedet
Re: $175 Class D amp--120 wpc
« Reply #1540 on: 10 Jun 2010, 08:57 pm »
Awesome!  Any pictures of the inside when it is in the DODD box?  That is what I am planning too!
Which amp is that, and why the HUGE heatsink?
Ted
TrungT
« Reply #1541 on: 10 Jun 2010, 09:02 pm »
Praedet
Check your PM
praedet
« Reply #1542 on: 11 Jun 2010, 12:31 am »
I wonder if one of these batteries will run both the amp and the buffer.  I have one in the garage...
http://www.caraudiodeals.com/kinetik-hc1400-p-1872.html
ichillpill
« Reply #1543 on: 12 Jun 2010, 09:37 pm »
Hi guys, I just bought a Norcom IEC and need help installing it for the ClassD.
1) It says 6A on the tag so does that mean I have to use a 6 amp fuse?
2) There are two fuse slots on the left and right...do I insert 2 fuses? I thought the 2nd might be a fuse holder but it looks like there are contact leads on both insertion sides
3) If I need to insert 2 fuses, do I insert 2 6amp fuses or 2 3amp fuses?
4) Lastly, there are 4 leads at the back top portion and 1 lead at the back bottom portion, where do I connect the 2 black wires and 2 red wires from the transformer?
I'm so confused and don't want to mess anything up.
avionic
« Reply #1544 on: 12 Jun 2010, 10:41 pm »
Hey Chill, 2 6amp fuses and yes you need both installed. Go to page 4 of this thread and you can see the wire set up for that IEC. It is at the bottom of the page. Easier than trying to explain.
ichillpill
« Reply #1545 on: 12 Jun 2010, 11:16 pm »
Thanks avionic! Last question, I can't quite make out the yellow wire from the bottom lead? Is that a ground to the chassis? This is optional right?
avionic
« Reply #1546 on: 13 Jun 2010, 02:08 am »
Yes that is a ground. Whether or not you use it is up to you. I certainly would and did. 2 minutes of your time to keep from getting the s_ _t shocked out of you :wink:
ichillpill
« Reply #1547 on: 13 Jun 2010, 03:16 am »
My enclosure is made out of wood though. Can I just put it on a big screw?
avionic
« Reply #1548 on: 13 Jun 2010, 04:05 am »
Sorry, didn't notice that you had a wood enclosure. I don't know what some of these guys have done. There are a few who have built these amps in wood enclosures. See if you can find some info in this giant thread.
Nick77
« Reply #1549 on: 13 Jun 2010, 10:38 am »
We have contacted Tom concerning grounding issues with a wood case and it has said that a ground isn't necessary with these amps. Of course if it was in a metal case it would be foolish not too. Myself and others have experienced no issues in a wood case with no ground.  :green:
ichillpill
« Reply #1550 on: 13 Jun 2010, 01:33 pm »
That's nice to hear.
Does it matter what amp the spst switch is? I found a switch that says 3A. Am I tied to the 6A on the IEC?
Nick77
« Reply #1551 on: 13 Jun 2010, 08:17 pm »
Should be 10-15 amp.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=060-670
wushuliu
« Reply #1552 on: 14 Jun 2010, 07:19 pm »
You can now order a custom aluminum enclosure direct from Classdaudio.
Looks familiar...  :scratch:  :lol:
srb
« Reply #1553 on: 14 Jun 2010, 07:29 pm »
Good idea, Jason.  You may want to have ClassDAudio correct a few misspellings in the Description.
1. this case is custom made to fin ... > to This and fit
2. This case is made and shipped directly from the manufacture. > manufacturer
jtwrace
    • TIPP YouTube Channel
« Reply #1554 on: 14 Jun 2010, 08:00 pm »
Quick and good eye.
Done.  Thanks.   :thumb:
srb
« Reply #1555 on: 14 Jun 2010, 08:07 pm »
Quick and good eye.
Quick website editing response!  Got the two misspelled words, just thought he might also want to start the second sentence with a capital letter (This).  Or not.
roymail
  • Roy in TX
« Reply #1556 on: 14 Jun 2010, 08:09 pm »
Jason, regarding the Class D website, the enlarged pics are HUGE.
They obviously need to be resized.  Great idea to make them available through the Class D website.
Just trying to help.  :thumb:
srb
« Reply #1557 on: 14 Jun 2010, 08:13 pm »
Yes!  I hadn't clicked on them before, but they are 3872 X 2592!
jtwrace
« Reply #1558 on: 14 Jun 2010, 09:21 pm »
Pics should be done tonight...
steve k
« Reply #1559 on: 15 Jun 2010, 12:06 am »
Congrats on the case deal Jason. That should make the classD's more marketable for sure!
steve
