0 Members and 5 Guests are viewing this topic. Read 1217937 times.
So given that the new amps have an input buffer built in, would it be superfluous to front end the input of the new class Ds with the Pass B1?
Changing amplifier input impedance (or changing polarity) may well have changed "imaging" in your system. It's hard to tell without knowing the details of your system, the comparison, and how you switched back and forth between the amps to do it. All that seems to have changed *in the amplifier* is the addition of an input buffer . . . different systems will have different need for and different response to that, and different people will draw different conclusions as to what that means. My system doesn't need an additional buffer, since my crossover's output buffers can drive the "original" board just fine, and I correct for polarity at the drivers. Adding a buffer stage would accomplish nothing for me. I'm glad it helped with your system . . . (did you set the "new" version for normal or inverted polarity?).
I’m not sure if it’s stated explicitly even in the IR Reference Design documentation . . . if it is I missed it. It is shown in a block diagram (Fig 24, page 20) . . . look at the input and output “signal graphic”:http://www.irf.com/technical-info/refdesigns/iraudamp7d.pdf
The only thing I changed due to the change in input impedance are the two caps in my DAhlquist crossover that set the high frequency cutoff. The cap value is based on the cutoff frequency, and the high/midrange amplifier's input impedance since it is passive. The bass cutoff is active.
You may want to hear something first before determining "the sound of the amplifier itself has not changed". That's a bit presumptious.
Are you suggesting that something in the amplifier has been changed in addition to adding an input buffer/phase inverter? Do you have any documentation of that? I'm sure many in addition to me would like to see a schematic of the new input stage, and especially any changes made in the amplifier itself . . .
This guy is fixing boards screwed up by "modders" when they're clearly out of warranty
That's a bummer. That's pretty lame for someone to send back a board after tinkering w/ it. That's definitely taking advantage.
Look, its a cheap amp that sounds good. I'm not going to debate the physics. I can't believe how critical some of you people are over a $175 amp! This guy is fixing boards screwed up by "modders" when they're clearly out of warranty and people are bitching about his webstie typos. Hey this isn't Wilson Audio, this is Cheap and Cheerful remember???This was fun for awhile till all the experts came along and picked it to pieces. Tom told me tonight this is precisely why he doesn't get involved in forums.I and my friends clearly hear a difference in the imaging of the Super D amp. Tom sent me one to verify this because he heard the difference and wanted some outside verifcation. That's all. I don't think I need to justify what Tom, myself and my friends heard to you. Be your own judge, but at least listen to it first.
That being the case, why would someone need a buffer?
I'm not sure under which circumstances one might need the better impedance matching of the input buffer, but because these amps seem to have higher gain (32) compared to most of the amps I've owned (26 - 29), adjustable gain might be helpful because 1. Your preamp has too much gain, so that the volume control has to be used within a very narrow range? 2. You have very high efficiency speakers, and reducing the gain reduces the background noise? Steve
Am I correct that the amp comes with the 32db gain setting as default but Tom will change it to 26db upon request? I think I read that somewhere on this thread.If that's the case, it will work well for me since I use a Goldpoint/Elna stepped attenuator with no gain, of course.
I believe on the superd you now have a switch to change the gain.
One of the reasons I am STILL hoping to put my hands on one of those Nelson Pass buffers.
It's comin'! Had to twist some arms to get the seller to send the missing panels...
That is exactly my situation. High efficient speakers etc. One of the reasons I am STILL hoping to put my hands on one of those Nelson Pass buffers. P.S (to all)we all enjoy constructive conversation/discussion but keep in mind that this is NOT "The Lab Circle" and most who found this kit interesting, love it because it's easy and cheap. Over-building/over-complicating this project might take some fun away from this thread. It can also discourage some folks from trying out this very simple kit that isn't only simple but cheap and fun. ThanksMariusz
