0 Members and 1 Guest are viewing this topic. Read 1205724 times.
I am considering getting this same case. Now that you've received your case, are you glad you bought it? I ask because they have some more expensive, black anodized cases which look like they might be a little nicer cosmetically.BTW, thanks to everyone for this thread. I've been looking for an amp for a while and, after reading this thread, ordered the 120 wpc CDA on Friday.
I have the second prototype complete. It's really nice. Next, are the finished anodized units.
Bill, I used heavy duty Al foil formed into shape by hand. You can see the wrinkles in the casting. I made multiple sizes and they work very well. Got lucky. A set of 3 easily supports 200 lbs (me). Dave
Thanks I may just might try some myself. Chambersburg well you just might find me at your door one day
jtwrace, any news (pics?) on the enclosures?-Jim
Ah...Poconos. We're in south-central PA, kissing the border, 80 mi WNW of DC. 20 mi West of Gettysburg.If you try the Dave tiptoes, let me me know. Suggestions!Dave
Herbie's stuff is really nice for footers. Though not as cheap as hot glue, they're very cheap and the best footers I have used. I'm using them under my amp.
The Super D's are up in the ClassDaudio page.My one minor quibble w/ Tom are the typos that pop up on the site. I've shot emails as a heads up,but some still pop up, and right now the main page has the word 'Ballanced' in giant red font...
I'm going to try for sure when the glue sticks are hard there tuff takes alot of heat to soften themI am the Pumpkinking..................Bill
I see the "Introducing our Super D series..." and photo, but I can't link to a product page, nor is it listed under Amps or Kits. Steve
The stuff I used is Arrow Super Power hot melt glue. I selected my sticks by manipulating them, sooth-saying, and a little prayer. I basically looked for the slowest restoration rate. I made the forms, cut the sticks up into ~3/8" pieces, filled the forms up, onto a cookie sheet and stuck 'em in the oven at about 250 - 275 deg F. Been a while but I think they melted rather quickly. CAREFULLY Pull them out like cupcakes and let them cool. The foil separates easily. The "tip" or bottom of the form must be flat to sit properly upright. There -- that's the basic primer! Dave
I really wish I had this product for sale, as I am 99% confident I could amass double whatever the current sales are and have even happier and more excited customers. Some of the things I would do are: 1. Have a simple model number for each amp. Referring to the 2 X 250 at 8 ohm , no 4 ohm, no 2 X 125 @, no, wait.......... Gets confusing, and trust me, there is a lot of confusion. 2. If a change is made, for example the 250W X2 @ 8 ohm (I think) is now useable at 4 ohm with an extended heat sink which is now supposed to be standard - the website information would be updated, along with an updated photo. 3. Create a matrix feature and specifications chart. I was looking at the Synology NAS devices for my computer, and wondered about the differences between some of them. Check this out! Sweet! http://www.synology.com/us/products/compare_spec.php 4. Post to the forum once a day to clear up questions. I know this takes up some designer/engineer/business owner's time, but a lot less time than answering the same question 10 times in 10 separate private emails. 5. Offer some "SE" upgraded boards, both amps and power supplies. You're dealing with 'audiophiles', why make those interested in better, bigger capacitors, etc. unsolder, toss away, source and buy new parts, then resolder? This would create some additional and larger sales and some happy campers. Just a few thoughts. Steve
