FS Onix Strata Mini Loudspeakers FS
0 Members and 1 Guest are viewing this topic. Read 1224 times.
SteveCornell
« on: 16 Jan 2010, 02:34 am »
I have a like new pair of Strata Minis for sale, these speakers have seen very little use and are in perfect condition, I have all the original packaging and could get them palleted and to a shipper if desired, I'm in central WV and would be glad to drive a couple hundred miles to meet a buyer at no cost.
I'm asking $1200 for the pair plus any shipping charges (if shipped)
Details....
Cabinet: Gorgeous real wood South American Rosewood veneer wrapped around a well-braced MDF frame.
System: Four way, four driver direct-radiating system. Sealed enclosure except for the 8" woofer which is ported via a flared slot.
Drivers: Planar magnetic 1" tweeter, planar magnetic 8" midrange, 5.25" mid-bass coupler, 8" mass-loaded woofer.
Amplifier: Built-in 350 watt class A/B for the powered woofer. Features crossover, gain, variable phase and high level/low level inputs and outputs.
Crossover Network: Custom-Designed by Danny Richie for av123 and including Air core inductors, polypropylene capacitors and non-inductive wire wound resistors. 4th order acoustic slopes on the upper end and 2nd order slopes on the bottom end.
Crossover Points:
8" woofer : 27 Hz - (user definable)
5.25" has a 1st order high pass at 80Hz
5.25" mid-bass coupler to 8" midrange : 650Hz
8" midrange to tweeter : 4100Hz
Frequency Response: 27 Hz to 35 KHz (± 3 dB)
Impedance: 8 Ohms nominal
Efficiency: 86 dB (@ 1 watt / 1 meter)
Dimensions: 47" H x 13.5" D x 11.5" W
Weight: 94 lbs each
