0 Members and 1 Guest are viewing this topic. Read 3510 times.
Regarding the important matter, the AC link is on the Salk site in the top menu under COMMUNITY, then pull down to Forum.
Jim--you make a number of good points (not including your appraisal of my crossovers, of course). And I think you may have tempted the pipester to try the simple biamp approach using the existing crossovers, since he seems to be more concerned about the quality of the tube sound, not just relieving the woofer amp of other duties. I was going to suggest that, but I wanted you to make the fist move because I wasn't absolutely sure how you wire the crossovers. I take it each filter has it's own separate ground, and that single amp operation is effected by jumpers between the two sets of binding posts?
Dennis - That is correct. If we provide bi-wire (or bi-amp) binding posts, the grounds are separate and we normally ship the speakers with jumpers installed (which obviously need to be removed if bi-wiring or bi-amping).- Jim
I should have known a private investigator could figure it out.
Great information Dennis and Jim. Thanks. And geez Dennis, take a deserved compliment from Jim. There are many of us Salk customers that want to believe you really are exceptionally amazing at engineering crossovers. Don't take the dream away! BTW Dennis, you're missing out by not listening to tubes!!
... Frank is such a genius. He can make a tube amp ... sound almost as good as his SS amps.
I can't currently drive both amps from with the same preamp because of gain and/or impedance dissimilarities between the amps.
oneinthepipe - Lastly, my experience has been that active set-ups can do wonders with lesser drivers. But with great drivers and Dennis Murphy crossovers, you simply can't get much better than the sound quality you get from a stock passively crossed speaker. Dennis' crossovers are so good, there simply isn't much room for improvement - so don't expect it.I hope this helps.- Jim
You don't think 300db per octave crossovers or active room correction would be worthwhile?
