0 Members and 1 Guest are viewing this topic. Read 2457 times.
So, I have recently purchased my first HD set (a 720p plasma unit), and now need to figure what to do, to optimize it for my sources.My satellite receiver can output 720p, or 1080i, or 1080p. So too my upconverting DVD player.What settings should I set my gear at?I presently have them both feeding my 720p unit with 720p, assuming that allows the tv to display in its native format.Am I missing anything?
You absolutely can adjust picture size and aspect ratio using HDMI, either in the TV or source.And yes, leaving everything at 720p should be fine.
I am not unhappy with the picture, though I am quite confused about my options to mess with the format - both my satellite receiver and tv have settings that can adjust for both SD and HD:ZoomJustifyFull (called Normal on my satellite receiver)4:3So, as a guy who has owned an HD set for 2 weeks now, I am still playing around with things, to see what this new technology represents.I am presently using the TV setting for HD set to Full, and the satellite receiver setting for HD set to Normal. This appears to be the most natural combo.ISF calibration sounds nice, but I am familiar with what it costs...I have researched the settings used by the website Plasma TV Buying Guide, and have my custom setting done this way, but I am respecting the break in period (using standard setting) at present.
