Yet another (possibly stupid) Piccolo question....
0 Members and 1 Guest are viewing this topic. Read 1344 times.
JimK
« on: 10 Jan 2010, 11:18 pm »
I'm still waiting on the final two resistors to arrive before I can let the smoke out fire this thing up, but I just noticed something today that has me scratching my head. When I installed the rotary switches I was very careful to keep the tabs "down"/pointed towards the ground lug. However, when the knobs are installed they don't/won't line-up similar to the OEM Piccolo.
For instance, my Piccolo, with both switches set at full CCW rotation:
(Don't you hate taking pictures of black gear? Every little speck of duct makes it look terrible...)
And the OEM Piccolo:
Should I be concerned about this, or should I just file a "flat" on the switch posts to compensate? I've thought about rotating them 180 degrees, but the top/gain switch has a three-pin configuration that only mates-up with the board one way.
Or I suppose I could always get new knobs w/o pointers...
Sorry to be such a PITA, guys.
analog97
Re: Yet another (possibly stupid) Piccolo question....
« Reply #1 on: 10 Jan 2010, 11:35 pm »
You're fine.  Just unloosen the knob set screw and line-up the arrow the best way you can.   The set-screw does not go into the flat side of the knob shaft.  The set scre will hold it just fine and dandy!!
JimK
« Reply #2 on: 10 Jan 2010, 11:39 pm »
I'll be much better once this thing is up & running... :lol:
