Why can't I install foobar?
0 Members and 1 Guest are viewing this topic. Read 3095 times.
gdg
« on: 10 Jan 2010, 12:24 am »
In the past I've by passed all the know-how that one needs to get good audio out of a computer by using a Squeezebox.
I find I now need to install Asio4all and foobar to optimize my Chaintech. When I try to install foobar I get a message asking me what program to use to open it. I have no clue what this is asking. Can anyone help?
srb
Re: Why can't I install foobar?
« Reply #1 on: 10 Jan 2010, 12:52 am »
Foobar is only currently available as a .torrent download.  You will have to dowload a torrent client to download the foobar executable, such as BitTorrent http://www.bittorrent.com/
After installing BitTorrent, you can use it to download the foobar executable file.  Add the .torrent file you downloaded from foobar (foobar2000_v1.0.exe.torrent) and click Start to download it.  After the download is complete, right click on the file and select Open Containing Folder.  You will see the foobar executable file (foobar2000_v1.0.exe) and you can double click on that to install foobar.
gdg
« Reply #2 on: 10 Jan 2010, 12:56 am »
Thanx so much dude!
(I realize it's noob question)   :?
*Scotty*
« Reply #3 on: 10 Jan 2010, 01:48 am »
Here are links to older versions of Foobar
http://www.oldapps.com/foobar2000.php
Foobar2000 0.9.6.8
http://www.oldversion.com/Foobar2000.html
versions are available up to Foobar 2000 .9 Beta9
No torrents required.
Scotty
gdg
« Reply #4 on: 10 Jan 2010, 02:16 am »
I downloaded BitTorrent  but it was telling me I needed to open a port because my router was getting in the way (no idea what to do). It looks like I need to do something else.
srb
« Reply #5 on: 10 Jan 2010, 02:50 am »
I don't have any special port forwarding set in my router, so it is more likely a firewall setting.  BitTorrent.exe needs to have Internet access, and when I installed it, it asked for access and I granted it.
Router and firewall troubleshooting can be tedious, so the easiest thing for you to do is download the latest previous version from Scotty's links, then you can upgrade to the new version when the standard http download for foobar becomes available in a few days.
