0 Members and 1 Guest are viewing this topic. Read 13981 times.
Hi After years of fighting to get decent sound in my rectangular room 19Lx12.5wx8h I am considering going to a OB speaker. My current speakers are Newform 645's and I am not happy with them. I am looking at the Nao2 kit from Music and Design, the OB 7 kit from GR research and maybe the Superv from GR. I have some concerns with each of them. The Nao looks interesting but there is not much info. about it. I like the ability to use cardoid or sealed box woofers with the system. I also have 4 8545 mids in my 645's that could be used in the Nao. The OB 7 looks nice and Danny Ritchie is a talented and inovative designer but the design uses cheap drivers and I am leary of the overall sound quality compared to a design using higher quality parts. The Super V is interesting and the most costly alternative. What worries me about it is the 12" pro coaxial driver and if it is refined enough for critical listening. Most 12" Pro drivers have some serious resonances in the midrange and these can be seen as peaks in the impedance. I don't know how audible it would be. Any help you can offer would be appreciated as I live far away from any large centers where I could hear any of these designs in person.ThanksBrianr
call Danny,he is easy to talk to and will help you out.....i went with the Super V
I owned OB-5, and was very impressed with them. Don't disregard GR just because they are not expensive. Read the lexicon thread here or elsewhere if you don't know what i mean ..
They have incredible output for a 7" driver. When you look at the distortion plots for the SS drivers on Zaph they generally have very low distortion and high quality.
There is a ton of feedback and reviews of all of our open baffle speakers in the GR Research circle.
Absolutely. I am a regular lurker at the GR circle, it's just that I did not find this specific thread and was wondering if it was somewhere else...
The Lexicon thread that was mentioned is referring to the new Lexicon BD player ($3K+) that turns out to be an Oppo BDP-83 ($499.) with a Lexicon faceplate, here is the thread: http://www.audiocircle.com/index.php?topic=76445.0The gist is that just because a speaker/driver is expensive doesn't necessarily mean that it performs better than a less costly unit.Best,Ed
A much, MUCH more telling measurement that will tell you more about how a driver will really sound is a spectral decay. That's where the truth will be found.
I agree that the measurements on the Zaph audio site may not be ideal but he does test a number of drivers with the same procedure so the results should have relative merit when looked at as a group. The Scan Speak SD1 motor does reduce distortion and also seems to keep the second order dominant while the higher order products are low in level.
Spectral decay tests are also on the Zaph site and they are harder to interpret
I'm not sure that my room is large enough for the Super V - the OB 7 may be a better fit.
