CES 2010 show
0 Members and 1 Guest are viewing this topic. Read 11601 times.
Laundrew
Re: CES 2010 show
« Reply #40 on: 13 Jan 2010, 04:46 pm »
Go for it James.... build it!!!!!!  :thumb:
Build it and they will come....
Moon Doggy
Re: CES 2010 show
« Reply #41 on: 13 Jan 2010, 04:51 pm »
Is that like a memory player?  I heard one DAC with a memory player and that may be one of the reasons it sounded so good (well better than good :) )
Jim Hamley
Re: CES 2010 show
« Reply #42 on: 13 Jan 2010, 05:03 pm »
James,
Would you share your impressions of the MG 1.7?
  • The Demo is Everything!
    • http://www.bryston.com
Re: CES 2010 show
« Reply #43 on: 13 Jan 2010, 05:12 pm »
James,
I have a pair on order but they tell me it will be weeks before they are in production.
They sounded absolutely superb at the show!
james
werd
Re: CES 2010 show
« Reply #44 on: 13 Jan 2010, 05:34 pm »
james
I talked to my dealer in Winnipeg and he claimed that one of their popular centre channels took 3 years to get into production after the CES show.....  :lol:
Think i am just going to forget about it.
vegasdave
Re: CES 2010 show
« Reply #45 on: 13 Jan 2010, 10:47 pm »
james
I didn't get a chance to hear them. How would you describe them, James.
Re: CES 2010 show
« Reply #46 on: 13 Jan 2010, 11:08 pm »
Open, spacious and very coherent with good low level micro signal resolution.
james
vegasdave
Re: CES 2010 show
« Reply #47 on: 13 Jan 2010, 11:20 pm »
Wow, that's a winner. I guess I missed out. Would it be ok to use a smaller amp (Bryston of course) to drive them?
brucek
Re: CES 2010 show
« Reply #48 on: 13 Jan 2010, 11:21 pm »
Be carful with some of the sound cards though - I have had a hell of a time trying to get some of them to 'see' all of the normal and hi-res sampling rates (44/48/88/96/176/192).
james
Huh, I guess I haven't experienced that, although I don't have a 192 sample rate card to experiment with. I presently use an M-Audio Audiophile 2496 card and it certainly recognizes (and displays) any rate you send it. I believe you use the same M-Audio card, but in the 192 version. They both use the same M-Audio Delta control panel and have similar specs (save for the 192 sample rate that I'm skeptical anyone can hear).
I've been using this card with foobar running the Windows Audio Session API exclusive mode (WASAPI) dll component that sends exact bitstream directly to the soundcard. I'm able to use WASAPI since switching to Windows 7 from XP. Quite a leap in audio performance. Gone are the annoying glitches since W7 offers much improved multi-tasking.
brucek
Re: CES 2010 show
« Reply #49 on: 14 Jan 2010, 12:41 am »
Hi bucek,
Yes I have the MAudio 192 and the Lynx
The Maudio 192 has problems with 176 for some reason but no issues with the Lynx. I am running Media Monkey on both with Windows XP.
james
math-geek
Re: CES 2010 show
« Reply #50 on: 14 Jan 2010, 02:35 am »
There is an awesomely positive review of the Dynaudio Contour s1.4s (sans Bryston amplification)  forthcoming in Stereophile.  Apparently with their popularity they were nearly forgotten in favor of some "boutique" mfgs.  It seems that they have rediscovered what I already know.
BTW, Bryston and Dynaudio ROCKS! :thumb:
khfm865
Re: CES 2010 show
« Reply #51 on: 15 Jan 2010, 09:19 pm »
Another Dynaudio and Bryston fan here! Running the contour s3.4 with bryston 4bsst2. Awesome. :thumb:
BrystonFan
Re: CES 2010 show
« Reply #52 on: 16 Jan 2010, 12:54 am »
Are they 4ohms ?
Always wanted to know how Brystons fare running 4ohm speakersb :scratch:
werd
Re: CES 2010 show
« Reply #53 on: 16 Jan 2010, 01:59 am »
Are they 4ohms ?
They are great at 4 ohm speakers, and with big drivers they can real shine.
|A good crossover will let lots of current through for nice low imp dips giving nice low freq extension. Bryston won't let up and will keep pounding the woofers uninhibited, unlike higher  imp designed speakers.
vegasdave
Re: CES 2010 show
« Reply #54 on: 16 Jan 2010, 11:23 am »
I wish I could afford big drivers! But even with my 2 8 inchers per side, the 4BSST really grips 'em!
khfm865
Re: CES 2010 show
« Reply #55 on: 16 Jan 2010, 01:38 pm »
Hi guys,
The dynaudio s3.4 is 4 ohms. My bryston 4bsst2 does not even break into a sweat at crazy volume. It is the best sounding amp I have tried. Used Plinius, Ayre and they can't match the bass I get in my system. Just sounds like the bass is deeper.
Cheers
