AV/O question
0 Members and 1 Guest are viewing this topic. Read 1500 times.
corndog71
  • Some people call me Rob.
AV/O question
« on: 8 Jan 2010, 10:19 pm »
I went through the archives but didn't really find an answer.
Would it be a problem to build the AV/O with the Neo3 tweeters?
Thinking about trying this as my next summer project if it's doable.
Just want to get the biggest bang for my buck.
Danny Richie
Re: AV/O question
« Reply #1 on: 8 Jan 2010, 11:44 pm »
Sure, it would work just fine.
emac
Re: AV/O question
« Reply #2 on: 8 Jan 2010, 11:51 pm »
Forget my post.  Found my answer.  Searching is a good thing.
Danny Richie
Re: AV/O question
« Reply #3 on: 8 Jan 2010, 11:55 pm »
Oh, it would need a completely different crossover. But the two drivers will work well together in that application.
emac
Re: AV/O question
« Reply #4 on: 9 Jan 2010, 12:06 am »
You're too fast, Danny.  To clarify my changed post, it looks like you could use the Neo tweeters in the A/V-1RS, but it would require a different crossover.  Thanks.
Danny Richie
Re: AV/O question
« Reply #5 on: 9 Jan 2010, 12:12 am »
Yes, that would also require a different crossover.
In that application I don't see a lot being gained over the standard A/V-1RS.
