Need Step-up Tranny
0 Members and 1 Guest are viewing this topic. Read 2980 times.
BikeWNC
Need Step-up Tranny
« on: 8 Jan 2010, 08:12 pm »
I've come to think lately, that I need a SUT for my Denon 103R cartridge.  I'm currently running it into the MC side of my tube preamp phono section loaded at 100ohms.  I guess what I'm wondering is would a SUT add more weight to the sound as I think it is a bit mellow.  Also, there is some tube rush from the phonostage I'd like to reduce or eliminate.  So would running the SUT into the MM input help with both these issues?
What would be a good SUT to try for the 103R that is transparent and won't break the bank?
BobM
Re: Need Step-up Tranny
« Reply #1 on: 8 Jan 2010, 08:59 pm »
Hagerman Piccolo, especially if you can solder. The kit and parts will only run about $150. Prebuilt it's $399.
Toka
« Reply #2 on: 8 Jan 2010, 09:17 pm »
Personally I'm big on SUTs with low-voltage MC's...just seem more "right" to me. With the DL-103 and variants I am a big fan of Cinemag transformers.
Wayne1
« Reply #3 on: 8 Jan 2010, 09:25 pm »
K & K Audio offers a couple of different SUTs either in kit form or assembled.
Moving Coil Step Up
Russtafarian
  • Typical reaction to the music I play
« Reply #4 on: 9 Jan 2010, 12:21 am »
You can wire up a pair of Cinemag CMQEE-3440A's. Around $60 each last I checked.  The Cinemags synergize nicely with the DL103.
http://cinemag.biz
SUT schematic: http://cinemag.biz/mic_input/CMQEE-3440A-Moving-Coil.pdf
Russ
BikeWNC
« Reply #5 on: 9 Jan 2010, 01:52 am »
Thanks for all the recommendations.  I'm not much with a solder iron so we'll see how it goes.  I'll take a look at all the SUTs mentioned.  I once looked into the cinemag trannys but the soldering stopped me.  Also, I might swap cartridges and want some versatility so the HagTech SUT might work.
choiraudio
    • Choir Audio
« Reply #6 on: 18 Jan 2010, 04:13 am »
The CineMag units are wonderful and when properly setup can work magic with the Denon 103 family of cartridges.
« Last Edit: 18 Jan 2010, 05:14 am by choiraudio »
dmckean
« Reply #7 on: 18 Jan 2010, 05:48 am »
If you don't want to solder you can buy pre-built cinemag step-ups here.
http://www.bobsdevices.com/cinemag.htm
taskerc
« Reply #8 on: 19 Jan 2010, 02:18 am »
I have Cinemags and the Piccolo and I confess I like he Cinemags just a bit more.  It can take a bit of effort to get the solution to be hum-free but it is worth it when you get there.  Biggest hum reduction tip I found is to tie the -ve of one of the signal RCAs to ground.  Not even much soldering to be done to be honest.
Chris
BikeWNC
« Reply #9 on: 19 Jan 2010, 02:55 am »
I decided to go the Cinemag way with the Bob's Devices SUT.  It came Sat. and I had it up and running that evening.  It certainly made a big improvement in the sound I was getting from the Denon 103R.  Thanks for all the suggestions.
