Other Stuff
Archived Circles
General Archive
Is it sonically bad to put center speaker on glass shelf?
0 Members and 1 Guest are viewing this topic. Read 9067 times.
bmg1
8 Jan 2010, 12:00 am »
Hi All.
I'm in the process of setting up vandersteen vcc-5 (part of an upgrade to all vandersteen fronts from B&W). I understand that there is a specific sound anchor stand for it. I also read in a thread that one can hang it over the TV from the ceiling!
I've an audio rack with 3 glass shelves (shroers & shroers lambda tv3). Would it be sonically bad to place the vcc-5 on the top glass shelf? Should I add some sort of isolation platform under the center and then place it on the glass shelf? My problem is that this audio rack would contain other things like DVR, DVD player, wii etc and this big vcc-5 might block it if I put it on a stand in front of the audio rack.
gerald porzio
Re: Is it sonically bad to put center speaker on glass shelf?
8 Jan 2010, 12:12 am »
Its a sure NO/NO. The glass will vibrate & resonate. If you have no other choice, use all the isolation @ your disposal between spkr. & shelf.
bummrush
Reply #2 on:
8 Jan 2010, 12:32 am »
get a little square of rubber slip stop, like used in cabinets to put glasses on, it comes in rolls, place under speaker, you wont even know its there
Wayner
Reply #3 on:
8 Jan 2010, 12:55 am »
I think it's sonically bad to have a center channel. Long live 4.1
Wayner aa
bmg1
Reply #4 on:
8 Jan 2010, 01:22 am »
Thanks all for the advice and innovative solutions!
Where can one buy a rubber slip stop. Home Depot / OSH maybe?
max190
Old Man
Reply #5 on:
8 Jan 2010, 01:31 pm »
Welcome bmg1,
I would check out the excellent products that are offered here...
http://herbiesaudiolab.home.att.net/
Also, Herbies has a forum on here for questions.
rollo
Restricted
Rollo Audio Consulting -
Reply #6 on:
8 Jan 2010, 02:02 pm »
Vibrapods at $6 each. easy affective and inexpensive. If your are the frugal type hockey pucks with a little Blu tac.
charles
mcgsxr
Mark in Burlington, Canada
Reply #7 on:
8 Jan 2010, 03:07 pm »
I had my bookshelf mains in my 2.1 HT on the main floor on glass shelves for years. I used blue tac to keep the speakers from vibrating on the glass surface. Worked great.
bmg1
Reply #8 on:
8 Jan 2010, 04:31 pm »
Thanks all for the great ideas! This center (vcc-5) is 70 lbs! I think I'll need about a bunch of vibrapods to bear the weight.
mcgsxr
Reply #9 on:
8 Jan 2010, 04:51 pm »
Sponge rubber hockey pucks might do it too, if they are available in your area - I have used them under my 100lb sub...
bmg1
Reply #10 on:
9 Jan 2010, 05:00 pm »
I ordered vibrapods!
I also came across this:
http://www.amazon.com/Auralex-Subwoofer-Isolation-15x15x2-inch-Charcoal/dp/B001140OZ0
Has anyone used this?
bummrush
Reply #11 on:
9 Jan 2010, 05:21 pm »
any Menards etc should have rolls of it,also when using it ,your speaker will totally stay in place there will not be any movement
Browntrout
Reply #12 on:
16 Jan 2010, 12:59 pm »
If you are using rubber under your centre speaker then it might be worth using it under all your speakers to make the sound the same from each.
Other Stuff
Archived Circles
General Archive
