0 Members and 1 Guest are viewing this topic. Read 6349 times.
Looking for Mono Bloc recommendations for my Salk HT3's 86db efficiency.Tubes I have heard, KR Audio's big tubes, KT88-66, EL34, 300b, 6h? Variant with Dynaco St70 and AVA70.I like a glorious midrange with the rosin on the bow sound, nice clean deep taught and articulate bass, with a extended natural sounding, not strident or forward, relaxed top end.I have been steered towards looking at the Jolida Mono Blocs and have heard the Envoy and was very impressed or maybe it was the associated MBL RadialStrahler's aa I need big power and current to drive my HT3's and I'm addicted to the tube sound Take a look at my systems for further insight to my gear and any and all recommendations appreciated.Off the list are CJ, Audio Research and Rogue.Would like to hear; Dodd 120's maybe not enough powerConsonance, Jolida Mono Bloc's, SupraTek.Thanks for looking
NiteshadeWhat does a pair of your 100w P-P monos cost?
the Consonance 211s are only 18W / ch and may not be enough to drive your speakers as desired. Now the 845 version SEt with more power may do it for you. My recco would be a push pull EL84 based design. If you still would like the SEt sound investigate the use of the GM70 tube. Maybe nightshade could make one for you. At least it will designed around your speaker. something to consider.charles
i don't know what the x-over point is on the ht3's woofers, but bi-amping w/a solid state amp on the bottom may open up more possibilities as to what would work w/tubed amplification on the mid/tweets.doug s.
Who currently manufactures crossovers for bi-amping? I see Marchand crossovers for sale periodically, but otherwise, I only seem to find pro-audio gear.
