Dodd Preamp - Capacitor Upgrade Question
0 Members and 1 Guest are viewing this topic. Read 12775 times.
GregC
« on: 4 Jan 2010, 08:14 pm »
I have a Dodd Audio battery preamp that I love, and I was thinking of asking Gary to change the Sonicap Platinum capacitors to Mundorf capacitors.  I love the sound of the preamp in its stock form (with the Sonicap Platinums) and I wonder if this is a case of "if ain't broke then don't fix it."  However, as an audiophile (who is on the endless quest), I cannot help but ask myself if I can improve on an already exceptional preamp.
I have a few questions of people who are more knowledgeable in this area.
I am thinking about Mundorf Silver-Gold or Mundorf Silver-Gold-Oil capacitors and wonder about the sonic differences between them.  Will Oil make the sonic character sound darker?
Is there a way to hook up a capacitor to something to break it in for 300 hours before using it in the preamp so I can avoid the painful break in process?
Is there a noticeable sonic improvement between Mundorf and the Sonicap Platinums that are currently in the preamp?
Thanks in advance for any advice in this area.  I can easily be happy with the preamp as it stands, but wonder what Mundorfs can add to the magic.
ctviggen
Re: Dodd Preamp - Capacitor Upgrade Question
« Reply #1 on: 4 Jan 2010, 08:38 pm »
Have you looked through that gigantic capacitor comparison thread?  That may provide clues.
I have a Dodd Battery Preamp that I've not yet used (room still under construction), but I'm also interested in replies to this.
GregC
« Reply #2 on: 4 Jan 2010, 08:48 pm »
Bob,
I found the capacitor thread after I posted.  So far I have not found how the Silver-Gold-Oils Mudorfs compare other than a mention that they are warmer than the Silver-Oils.  Also, it would be great to hear from other Dodd owners with personal experience.  I am one of the original 20 owners and the preamp is a foundation of my reference system.
Greg
jtwrace
    • TIPP YouTube Channel
« Reply #3 on: 4 Jan 2010, 08:52 pm »
Have you asked Gary his opinion?
GregC
« Reply #4 on: 4 Jan 2010, 08:57 pm »
I asked Gary and now I am soliciting feedback from the AC community.  Gary did not have experience with the Silver-Gold-Oil capacitors but he has some customers who are happy with the Silver-Gold capacitors.
jtwrace
« Reply #5 on: 4 Jan 2010, 08:59 pm »
Cool.  I'll be following....
jtwrace
« Reply #6 on: 19 Jan 2010, 07:39 pm »
any updates?
Danny Richie
    • http://www.gr-research.com
« Reply #7 on: 19 Jan 2010, 07:53 pm »
Typically the Silver/Gold/oil caps tend to soften or truncate transient peaks.
I have had some experience with them in a loudspeaker circuit comparing those Mundorf's to Sonicaps by-passed with Platinums. The Mundorf's gave up a lot of resolution in the top end and the sound stage was much more two dimensional compared to the Sonicaps. Later adding Sonicap Platinum by-pass caps to the Mundorf's brought them around and made it closer.
Clearly the Mundorf's (that type anyway) color the sound, but do so in a way that some people like with their systems.
I'd be more inclined to try the Mundorf's in place of the 3.3uF Sonicaps and leave the Platinum by-pass caps. A 3.3uF is pretty large though and I don't know how easily it will fit.
bluemike
« Reply #8 on: 19 Jan 2010, 08:10 pm »
I have a pair of Dodd Amps and looking for a cap change after alot of reseach i'm going with the Audiocap Pcu
for preamps I would go vcaps if those are too spendy check out the relcap or multicap lineup
jtwrace
« Reply #9 on: 19 Jan 2010, 11:24 pm »
Let us know how it goes.  Are they 120's?
bluemike
« Reply #10 on: 20 Jan 2010, 02:38 am »
yes they are ..I know of another poster who's ears I trust that went with the Audiocap pcu and was very happy with them - He actually preferred these over the sonicaps plats in his dodd amps
Will report how they sound once installed
Anyone else heard these caps in audio equipment and care to comment ?
RPM123
« Reply #11 on: 20 Jan 2010, 04:14 pm »
"However, as an audiophile (who is on the endless quest), I cannot help but ask myself if I can improve on an already exceptional preamp."
Try swapping tubes instead... it's a lot easier!  :)
jtwrace
« Reply #12 on: 20 Jan 2010, 04:19 pm »
What generation?
GregC
« Reply #13 on: 20 Jan 2010, 05:47 pm »
I have tried at least 8 different sets of tubes until I decided on my reference 1965 White Label USA 7308 Amperex tubes (with a set of early 1960's Telefunken E88CC tubes as my backups).  I agree that tube swapping is the best place to start.  I love the preamp "as-is" and I hesitate to change it for the sake of change, especially if Mundorfs color the sound.  The pre-amp is extremely neutral and resolving and I prefer to not add any colorations.
bluemike
« Reply #14 on: 22 Jan 2010, 01:32 pm »
What generation?
version 2 with upgraded finish these really look the part
NagysAudio
    • http://www.nagysaudio.com
« Reply #15 on: 26 Jan 2010, 12:11 am »
You should really try the ERO MKT1822 capacitors. They work great as coupling/filter caps and are some of the best sounding caps on the market.
GregC
« Reply #16 on: 26 Jan 2010, 12:17 am »
Thanks for the tip.  On the Humble Homemade HiFi it only rated the cap at 6+.
NagysAudio
« Reply #17 on: 26 Jan 2010, 12:20 am »
He rated the Vishay MKT1822 a 6+, not the ERO version. There's a significant difference between the two, I have used them both extensively in my designs. Problem is, is that ERO no longer makes caps, so you can only get them on eBay as new old stock...
GregC
« Reply #18 on: 26 Jan 2010, 12:53 am »
That makes perfect sense.  I would just need to find a pair of 3.3 MFD or else run them in parallel.
NagysAudio
« Reply #19 on: 26 Jan 2010, 01:08 am »
That might be a bit difficult, there's not that much room inside that preamp, as you might have to parallel 3 of them to get that particular value. I also like the Jantzen Z-Silver caps and they do have the standard 3.3 uF values...
