Joined the Eminence club :)
0 Members and 1 Guest are viewing this topic. Read 2721 times.
Jtoivonen
« on: 4 Jan 2010, 06:59 pm »
So here they are!
4 Alpha 15A's, 2 modified Beta 10 CX's (the throat has been machined to fit the seas tweeter) and a pair of Seas  25 Taf gn neodumium tweeters.
Most of the mechanical work is done and the painful and long episode of tweaking begins.. Most likely they will be triamped. I'll report as the project continues :)
Here are some pics:
freddyi
Re: Joined the Eminence club :)
« Reply #1 on: 4 Jan 2010, 07:03 pm »
cool! - what had to be done to 10CX for the new tweeter to fit?
Saurav
« Reply #2 on: 5 Jan 2010, 02:38 am »
Do you have any pictures of the back?
Jtoivonen
« Reply #3 on: 14 Jan 2010, 08:50 am »
Not yet but I'll post some soon.. But there's nothing special about mounting that tweeter . You just need to make adapter to adapt Tweeters 34 mm throat to woofer's throat. And glue that in there..
Some testing done and versoon 4 of x over done.. Seems that woofer and midrange work just fine with passive X over, but Tweeters will be driven with  another amp because of their low sensitivity.
