6BQ7A
0 Members and 1 Guest are viewing this topic. Read 4977 times.
Bmotorcycle2003
6BQ7A
« on: 3 Jan 2010, 11:17 pm »
Is a 6BZ7 a substitute tube for a 6BQ7A?  Thanks...........Bob
Ericus Rex
Re: 6BQ7A
« Reply #1 on: 4 Jan 2010, 01:13 pm »
You should post this in the Tube-o-phile circle.  You'd get more hits.
Roger A. Modjeski
Re: 6BQ7A
« Reply #2 on: 17 Jan 2010, 10:29 pm »
Like most "A" tubes they are substitutable otherwise they would have gotten a new number. In many cases the A version has had it's filament warm-up time adjusted to a standard for series filament radio and TV. This makes no matter to us in audio. The 12AX7 is an exception in that they shortened the plate a few mm in the A version but again they are interchangeable.
FYI the largest change I am familiar with is the lineage of the 6L6 where the style went from metal (no letter) to glass (G), then GA, GB all of which had the same characteristics. In the GC they thickened the plate material, made it bigger and boosted the dissipation rating from 19 to 30 watts. However the lower dissipation is design center and the higher one design max which obscures the real amount of increased dissipation.
Bmotorcycle2003
Re: 6BQ7A
« Reply #3 on: 18 Jan 2010, 04:36 am »
Roger thanks, welcome back and condolences on the loss of your parents.
I appreciate the clarification on the addition of the "A" to the 6BQ7 but, I was wondering if the 6BZ7 tube can be substituted for the 6BQ7"A" tube.
http://cgi.ebay.com/Radio-Vacuum-Tubes-6BZ7-6BQ7A-ZENITH-5-NIB-NOS_W0QQitemZ130359853749QQcmdZViewItemQQptZVintage_Electronics_R2?hash=item1e5a0d82b5
« Last Edit: 19 Jan 2010, 12:38 pm by Bmotorcycle2003 »
