0 Members and 1 Guest are viewing this topic. Read 5526 times.
I don't know all that much about speakers, but it would seem to me that the designs are so close and the drivers are the same (minus one woofer) that the main difference would be output capability. I doubt things like imaging, soundstage depth, and width would differ at all.
Thanks for the replies, I was having a difficult time choosing between the two.Now I have a better understanding to make a decision. Thanks again.
I understand how tough your decision is between the two. For me it would come down to room size. If you have a smaller room, the HT1s would most likely be fine. If you have a medium to large room, I'd spring for the HT2 with the thought that they would need to play louder. Even if you use a subwoofer, the extra woofer in the HT2-TLs can make a BIG difference with upper, midbass.
Is anyone using the HT2-TL's in a room approx 13' x 19'? I want to listen to 2ch direct, 5.1 hi-rez, as well as HT and hope they wouldn't over power the room. Thanks,Ken
Talk to oneinthepipe; he has HT2 TL's in a smallish room.
