0 Members and 1 Guest are viewing this topic. Read 11792 times.
PS, the motor doesn't make noise with the belt off, so the motor should still be good.
I had a TD 125 until about 2 years ago. Many replacement belts for this tt were a little too tight and put too much pressure on the motor shaft. I tried 3 vendors and finally found a belt that fit correctly... and no more noise. My recollection is that the $25 belt was worth the cost. I wish I could remember the vendor that I found online. Hopefully, the right belt will solve your problem.
Was it LPGEAR? They have done good for me in the past with Empire belts, tho expensive ($30).Wayner
The large circuit board under the turntable adjusts the generator that drives the motor. I've found that if the adjustments are out of spec, you can clearly hear the knocking sound from the motor, and when it's adjusted properly the motor will be quiet.
