listening at low volume
0 Members and 1 Guest are viewing this topic. Read 1858 times.
nikon
« on: 30 Dec 2009, 07:30 am »
got these for christmas for listening at low volume ...
1oldguy
Re: listening at low volume
« Reply #1 on: 30 Dec 2009, 12:49 pm »
I feel so envious,There I admitted it. :duh:
Mad Mr H
« Reply #2 on: 30 Dec 2009, 01:03 pm »
I see you went for the "Custom" option and had each side tuned to suit your specific hearing needs.
Do you find that the signals from inter planetary craft are much clearer than when you use the x-men helmet? I get very confussed with that.
One person was reported to spontaneously combust when they got caught in the solar rays - Were OK in the UK on that front as we only get precipitation in the air, or recently white solid water on the ground.
Wait till our resident "robot" guru set about modifications...........
1oldguy
« Reply #3 on: 30 Dec 2009, 01:25 pm »
Glad to see I'm not the only one who feels this way.I thought it was all in my head.
John Casler
« Reply #4 on: 30 Dec 2009, 03:46 pm »
Good for both SET and SETI uses aa
Increases spaciality :thumb: (sonic depth of field)
Also gives a whole new aspect on "tubes".
Also allows you to listen to your friends systems (from your house)
rob80b
« Reply #5 on: 30 Dec 2009, 07:22 pm »
Curious if they would work better with Grado flats or bowls.
Robert
