***SOLD SOLD SOLD SOLD***
0 Members and 1 Guest are viewing this topic. Read 2650 times.
kgturner
« on: 30 Dec 2009, 06:52 am »
I am selling my Art Audio Carissa (see below for features & specifications). This is a fantastic 845 based SET amplifier with beautiful polished stainless steel chassis. It is S/N 1184, Standard version, not Signature, but it doesn't seem there's much real difference between the two. I have owned this amp for less than 2 months as I purchased it to demo against my current reference amplifier, a 2 watt Yamamoto A-08S with Emission Labs 45 Solid Plate tubes.
Frankly, there wasn’t a huge difference between the two. The Carissa excelled in some areas while the Yamamoto excelled in others. In the end though, the Yamamoto just added a little extra sparkle which I preferred. Some might call it forward, but I prefer it none the less. To each his own I suppose.
Conservatively rated 8/10 but in all honesty I would rate this unit 9/10. It is in excellent condition with no known/visible flaws and has low hours. I will include some great tubes, all in excellent condition:
Tubes Included:
Amperex Holland 6922 input
Pair Tung-Sol 12BH7A drivers
Pair Rauland 12BH7A drivers (I believe RCA)
Pair Valve Art 845, excellent with low hours
I will also include the original manual. I do not have the original box but it will be very well packed as always. I accept payment via PayPal or USPS Money Order. Shipping & insurance to the lower 48 states will be a flat $60.00. No charge for PayPal.
Features:
Lower plate voltage for prolonged tube life
Factory set dual mono biasing circuits
Quality MOSFET regulated power supply
Custom hand-wound split-core output transformers
High quality mil-spec, multi-layered 2-oz. copper trace circuit boards
Capacitors are low ESR/ESL types for increased high frequency performance
Resistors are 1% metal oxide for low noise
Hand-polished, non-magnetic, stainless steel chassis and transformer cover available
Specifications:
Type:                       Single-ended, transformer-coupled, pure class A, triode stereo amplifier
Output Power:            16 Watts per channel
Input Sensitivity:        600mV
Input Impedance:        4 - 8 ohms
Output Impedance:      180K ohms
Frequency Response:   20 Hz to 60 kHz ± 1dB. at full rated power
Tube Complement:       1 x 6DJ8/6922, 2 x 12BH7, 2 x 845
Dimensions:                12.75” x 18.5” x 9” ( W x D x H )
Weight:                     70 lbs.
« Last Edit: 30 Jan 2010, 01:45 am by kgturner »
kgturner
*bump*
« Last Edit: 18 Jan 2010, 04:58 pm by kgturner »
kgturner
Re: FS: Art Audio Carissa (845 based SET Amplifier) $2000.00 OBO
« Reply #2 on: 11 Jan 2010, 03:10 pm »
upsie daisy
« Last Edit: 18 Jan 2010, 05:00 pm by kgturner »
kgturner
« Reply #3 on: 15 Jan 2010, 08:03 pm »
boopy doop
kgturner
« Reply #4 on: 26 Jan 2010, 02:49 pm »
one more time
