"Quite Simply in a Class by Itself!" - ENJOY THE MUSIC.com 9B-SST2
0 Members and 1 Guest are viewing this topic. Read 5081 times.
  • The Demo is Everything!
    • http://www.bryston.com
Hi All - Preview for you. Full Review will go on-line Jan 1, 2010
February / March 2010
World Premiere
Bryston 9B SST2 C-Series Monoblock Power Amplifiers
Quite simply in a class by itself.
Review By Brett Rudolph
The End Or The Beginning....
It is not often that it seems that the end of a review comes far too quickly, but alas this was one of those cases. One of the conditions of the review was that it be done as quickly as possible because there were not many review units available, so I did my best. However, it was not without a sense of remorse that the amplifier made it way to the shipping depot.
The Bryston 9B SST2 class C is quite simply in a class by itself. Its ability to yield precise, uncompromised music is something that is rarely ever seen and almost never in an amplifier in its price level. Of course the Bryston 9B is in no way inexpensive, for the 5 channel configuration costs $6695. Yet, while that might not seem a bargain, take it from someone who knows, it is. In fact, it might even be considered a bargain at an ever higher price point.
In short, if you are in the market for an amplifier, especially a multi-channel amplifier, you owe it to yourself to give the Bryston 9B SST2 class C a chance. It is likely to give you a performance you are not likely to forget.
Personally this is one of the only amplifiers I have ever dreaded sending away and wished it could have stayed longer
« Last Edit: 21 Jan 2010, 12:46 am by James Tanner »
Re: "Quite Simply in a Class by Itself!" - ENJOY THE MUSIC.com
« Reply #1 on: 31 Dec 2009, 04:32 pm »
Hi Folks,
Complete review:
http://www.enjoythemusic.com/superioraudio/
james
Dilbert
« Reply #2 on: 31 Dec 2009, 04:40 pm »
Very good. James, am I correct in assuming that a 9B is essentially five 2B's in a single box?
« Reply #3 on: 31 Dec 2009, 04:47 pm »
Hi,
No the 2B SST has 100 watts @ 8 ohms and has 2 ouput devices per channel.  The 9B is 140 watts and has 4 output devices per channel and a much larger power supply.
james
rudy
« Reply #4 on: 1 Jan 2010, 02:54 pm »
Isn't it odd that he used the word "incarceration" at the end of the first sentence in his second paragraph?
« Reply #5 on: 1 Jan 2010, 03:05 pm »
I assume its a typo?
james
rudy
« Reply #6 on: 1 Jan 2010, 03:10 pm »
Something an editor should have caught.
« Reply #7 on: 1 Jan 2010, 03:17 pm »
I will contact the editor and get it fixed.
james
« Reply #8 on: 1 Jan 2010, 05:45 pm »
james
Fixed.
james
« Reply #9 on: 1 Jan 2010, 07:51 pm »
Hi,
james
Hi Mr.Tanner,
Please, clarify my doubts:
You mean said the 2B-SST2 have one transistor pair per channel??
How many transistors pairs per channel have the 3B-SST2 ??
In my country the mains electrical is 220Volts(205-213V in real life), Bryston made 220V amps? or only the EuroZone 230V??
Thanks for your input,  Gustavo
« Reply #10 on: 1 Jan 2010, 08:30 pm »
^ Hi,
Yes the 2B SST has a PAIR (2) of devices per channel. The 3B SST has 4 devices per channel.
We make 220, 230, 240/50Hz volt versions of the amplifiers.
james
« Reply #11 on: 1 Jan 2010, 10:14 pm »
^ Hi,
james
Thanks for your support Mr.Tanner.
Do you think 205-213Volts is too LOW for a 220Volts Bryston 2B or 3B ??
Could be dangerous or bad sound result running a 2B/3B in a mains like that??
Gustavo
« Reply #12 on: 1 Jan 2010, 10:22 pm »
^ Hi,
james
Gustavo
No it is not really a problem.  Our power supplies can operate over a fairly large voltage change.  The issue will be more or less power capability as the voltage rises and falls.
james
« Reply #13 on: 1 Jan 2010, 10:41 pm »
Thanks alot for your friendly support Mr.Tanner.
Wish huge sucess to Bryston in 2010.
Gustavo
« Reply #14 on: 21 Jan 2010, 12:29 am »
Hi Folks - Sneak peak at new review on 9B SST-2
Bryston 9bsst2
Multi-channel Amplifier
Jared Rachwalski
Intro
Bryston is known for building some of the most sought-after, powerful and dependable amplifiers in the business. For over 40 years they have provided one of the most comprehensive warranty coverage of any manufacture of any product (not just audio), a 20 year transferable warranty, practically unheard of in this or any industry. If you find one, (that is if you can find one) on the used market chances are it will still be under warranty. There rare appearance on the used market has as much to do with there sound quality and dependable (high) power delivery as it does with there warranty.
Based in Ontario, Canada Bryston has grown to become one of the industries largest independent electronic manufactures. Their products include power amplifiers, pre-amps, processors, CD players, DACS and more. Yet they do not just grab any OEM machine, slap a matching face-plate on and call it a day, they engineer and thoroughly test all their gear before it ever gets to our audio shops.
They have a quality control program that ensures every individual hand built amplifier is tested not once, but three times before leaving the shop. First the amplifier components are tested before being assembled; then the unit is tested a second time after it has been assembled, and finally it is tested after the intense 100 hour burn-in session. This final test is recorded on a data sheet that is included with every amp. This shows Total Harmonic Distortion at full rated power, Intermodulation distortion, noise level with the inputs shorted, and the output power at clipping. The amp I received tested above the rated 140 watts per channel.
This is all well and good, but how does it sound?
Outro
We will get to the sound in just a moment, I swear. First let’s marvel at the beauty of the 9bsst2. The unit is available in 17” and 19” black or silver faceplates. There are handles on the back and front (19” version) that help when moving this beast around. The face has a power switch and an LED for each channel. This LED will change color depending on the channels state, red indicates muted, green indicates normal operation, flashing red indicates channel clipping and orange indicates thermal shut down.
The back panel of an amplifier is usually pretty mundane. Not so with the 9bsst2, each modular channel has single-ended (RCA) inputs, balanced inputs (1/4” and XLR in the same connector), binding posts that will take most any size and type of connector (up to 3 gauge bare wire!), polarity switch (allowing for bridging the channels) and a three-way gain switch (great for matching to a wide-variety of pre-amps).  The 9bsst2 is a modular design, with each module having an independent power supply, yet all share the same power cord. The detachable 15amp cord plugs into an IEC socket on the far left of the back panel, which also houses a magnetic-trip circuit breaker which further protects the amplifier. On the same panel you will also find a 12volt trigger (in/out).
Speaking of modular, the 9b is available in 3, 4 or 5ch version, and if something was to happen to one channel you simply remove that module and send in for service. Thus leaving you with the rest of the amplifier channels to power your speakers.
Overall, the 9bsst2 is not a new amp, rather an improved version of the original 9B-NRB from 1998. After the unit was modified and re-designed by Stuart Taylor the name changed to a 9bsst, and since then more refinements added the 2, or squared, designation. This change included a new soft-start circuitry, new RF input filters, the input impedance increased, and there are improved input and feedback capacitors.  What this translates to is a smother high-frequency response (not as clinical as before), improved power-band (more consistent sound throughout the entire operating range). As well as lower measured THD and noise.
Setup
After unpacking this 75lb beast I connected it via the single-ended inputs to my Denon 4308 receiver’s pre-outs. From there I connected five Martin Logan electrostatic loudspeakers with 12gauge wire terminated with banana plugs. Before flipping the magnetic-circuit breaker switch I set the gain switches to the 1volt setting as recommended in the thorough user manual, and ensured all polarity switches were at 0 degrees.
After that I re-calibrated the Denon and got down to business. Sources used were an Oppo 981-HD universal player sending SACD and DVD over HDMI to the Denon, an Onix XCD-88 HDCD player via co-axial digital connection for Redbook and HDCD playback, and a PS3-slim for Blu-ray. And this is where things really get fun.
Music
There are five channels in this powerhouse, and I intended on using them all, at once when possible. As such my music selections focused on multi-channel SACD and Blu-ray concerts. As well I threw some more challenging 2ch SACD music and HDCD titles.
The first disc I like to enjoy with a new component is the MFSL multi-channel recording of the Cowboy Junkies first album, Whites off Earth Now. This is a superb quality SACD release that has amazing dynamics for a non-classical album. This is great for testing the power-band of an amplifier. Does it sound musical at low volumes, mid volumes or only at reference levels? The previous high-power amp in my system, a Rotel RMB-1575 Five-Channel Class D Power Amplifier, was fantastic at resolving detail and sounded great at mid to high volumes. From low to mid, it just wasn’t alive. The Bryston on the other hand gets going at low volumes and keeps it musical presence all the way to the top (well as loud as I was able to push the MartinLogans – which was considerably louder than my normal levels).
As well this disc has phenomenal high-frequency resolution (thanks in part to the SACD format). There is an air and ambience to the recording that I had noticed before, yet never experienced quite like I did through the 9bsst2. There was no artificial hiss or colorization of any kind, and given the clarity and speed of the Electrostatic panel used in the Summit X’s any symmetry concerns with using this amp with electrostatic panels was soon dismissed.
Seeing as the SACD player was warmed up I jumped into something rather different. Rock, Punk, Alternative, Grunge however you choose to categorize them, the Pixies were somewhat of a unique band for their time. What makes there albums great for critical listening is they complexity of the music combined with shear loudness really test your systems ability to play loud and detailed at the same time. And there is no better sounding version than the MFSL (Ultradisc UHR 2ch SACD) remakes done in 2008. These were taken from the original analog master tapes and have substantially more dynamics and clarity than all the previous CD releases. Using the Pixies first album, Surfer Rosa, I tested the Brystons' ability to resolve complex detail at high volumes with heavy rock. The Pixies are known for sudden stops and starts in there songs and the 9bsst2 kept the pace going. From hearing the decay of the cymbals, the bantering of the band to the soaring crescendos this amp never broke a sweat, sure it got warm, but never once was there audible compression or distortion.
If only someone would release some Tom Waits on one of the high-res formats. Until then I will have to keep my Onix-xcd88 Redbook/HDCD player. Using the internal DACS (Burr-Brown PCM 1738 24-bit/192kHz) on this fantastic player I sent the analog outs into the Denon 4308 and ran it in Pure mode. First up was the exceptionally recorded Tom Waits disc, Heartattck and Vine. Once again there was no issues resolving detail, the punch and dynamic range was fantastic and there seemingly unlimited headroom.
The final musical test came from my HDCD torture-test, Tool’s Lateralus. Here is where I expected things to get ugly. I mean come on, Bryston amplification, Electrostatic speakers and a CD source playing heavy distorted progressive rock? This has all the workings of a shrill, analytical and overly-clinical sound. Or so people would have you believe. From on-line forums to my local HiFi dealer (who is also a ML and Bryston dealer) everyone predicted this to be a poor match. And if that was the case it would surely happen when I pushed the amp to high levels feeding it a highly detailed, heavy rock distorted sound. I can positively report there was no issue. I heard more detail in the percussions than with any other amp/speaker combo. There was amazing amounts of headroom which created a dynamic range that I thought were impossible with this album. Gone was any hint of compression at high volumes, and at almost every volume point the sound was consistently detailed and musical.
The newest high-res format is now here thanks to Blu-ray technology. With the massive storage capability of the format we can enjoy a significantly less compressed DTS and Dolby Digital feed, now called DTS Master and Dolby Digital True HD.
For movie playback I threw a wide range of movies at the Bryston. From the rain-soaked dialogue scenes in Seven, to the widely explosive Terminator Salvation the 9bsst2 was solid and consistent in driving the difficult load presented by 5 electrostatic panels. At no point did any clipping-indicators light-up, and other than some decent heat production I found no issues with movie playback. Compared to the Rotel Class D this amp is toasty, and does benefit from an open cabinet.
Conclusion
Amplifiers are a tricky beast to review. One would think there would be a hugely obvious difference between amplifiers, yet when you get down to it the differences are minute at best. I did not notice a life-changing difference going from the Denon’s built in amps to the Bryston, nor did I notice a significant output difference. Instead where I found the greatest change was how the low-level info changed. With both the Denon and the Rotel amplifiers they never shined until at mid to loud levels, where the Bryston was an absolute joy to listen to at every level. The 9bsst2 was able to constantly deliver high-power to an entire Mratinlogan five speaker set without issue.
Add an industry-leading warranty, massively over-built products and the ability to drive hard loads makes this amp a serious contender. If you want a solid purchase that will outlive your system and you like your amplifiers to amplify and not color the sound then the 9bsst2 needs to be on your list.
Jared Rachwalski
