0 Members and 1 Guest are viewing this topic. Read 2451 times.
I like the G11. However, it seems bulkier than the G10.
I also recently bought a G11 as a backup to my EOS 1Ds MkII, as I needed something lighter and less conspicuous. Thus far, I'm pretty pleased with it. Like you, it's low light, low noise capabilities were a major positive for me. I'm a little unhappy with the placement of the control pads on the back, I'm always bumping them inadvertently. Shutter lag still bothers me compared to a good dslr, but it's the nature of the beast. It does have remarkably good image quality for the price though. I've found the pivoting lcd screen to be quite useful for composing shots when you need to get a higher vantage point than eye level. All in all, it's one of the leading cameras in it's category. However, I'd still consider the Olympus Pen EP-2 as well (even though it's twice the price.)
Quote from: Levi on 31 Dec 2009, 12:52 amI like the G11. However, it seems bulkier than the G10. Come on, don't wimp out over a few ounces weight in your palm. You need that weight to stabilize the image. aa
Quote from: Photon46 on 30 Dec 2009, 12:47 am..............I need to learn how to use all the manual settings and am currently looking for a good book since the manual only tells you that you can change settings but never when or why.Just thought of this - If Canon is as good as Panasonic in support, there should be a tel. #, 800 # I hope, you can actually call, and they at the other end actually can take/talk you through, with your camera in your hand. Sometimes, it's pretty good. The 800 # is usually at the very end of the manual.Good luck, and happy new year!
