0 Members and 1 Guest are viewing this topic. Read 15255 times.
Thanks, guys.I will try the clay for starters. My table does not have a particle-board bottom...the bottom of the table is open so that you can see the electronics and the open cavities in the MDF.John - if I'm reading you correctly, it sounds like in my case the weights may do the most good.In the back of my mind, I'm almost wondering if an entirely new plinth is in order... Thanks,Joe
Certainly some key issues, as John has pointed out are internal resonance of the plinth, for starters. Easier said then done. I am also a big fan of plasticlay (non-hardening modeling clay) but the MDF is also suspect. Speakers are generally made of MDF as it is a great base material to make cabinets out of, then line them with your favorite flavor of wood veneers. The one thing that speaker manufacturers do to eliminate the internal microphonics is to add internal bracing. This stiffens the cabinet and prevents some energy transfer. As you may be figuring this out on your own, there isn't one simple cure, rather it requires several approaches to a quiet plinth. Not knowing what the internal cavity looks like, I would attempt to glue in some more internal braces to secure the top of the plinth to the sides. Then, plasticlay up as much as possible, staying away from electronics or moving parts as much as possible (don't know if this model is automatic, semi-automatic or totally manual). I would also line the inside of the bottom cover with a thin layer (about 1/4" think) to also help stop noise from ping-ponging around in the plinth.Many new table designs do do have any hollow in the plinth at all, mostly MDF or MDF sandwiched between some acrylic.Wayner
Wirenut The QL-7 is manual, A7 is auto-lift and the Y7 is auto-return. I have an A7 and Y7.Jack
Yep, unless you use something like the Q-Up. It is a better deck all around, but not for you if you want some form of automation.
