What is the longest lasting power tube?
0 Members and 1 Guest are viewing this topic. Read 2725 times.
Niteshade
    • Niteshade Audio
« on: 29 Dec 2009, 03:21 pm »
Out of all the power tubes you have used- what has served you the best? I'm not looking at any specific brand or type-  what's been good for you? I'll include rectifier tubes as well.
Keep in mind how your tube amp is set up: Does it have good air circulation? Are the tubes biased hot or not?
zybar
Re: What is the longest lasting power tube?
« Reply #1 on: 29 Dec 2009, 03:31 pm »
The 6AS7G output tubes that are used in Atma-Sphere amps are good for 10,000+ hours.
Mine don't have quite that many hours, but they are rock solid and I expect them to stay that way.
George
AudioSoul
« Reply #2 on: 29 Dec 2009, 06:22 pm »
I would think that would be according to many variables. Some amps by design has a higher bias setting than some amps. Environment, What kind of climate you live in. I live in the mountains of Arizona where it gets hot in summer and cold in winter. I have no air conditioning. Therefore I have a winter system (tubes) and a summer system (SS). And as you said allowance for adaquite ventalation...... 8)
decal
« Reply #3 on: 29 Dec 2009, 09:05 pm »
The spare set that is still in the box !!!!!!!!!!!!!!!!!!!!!!!
rollo
  • Rollo Audio Consulting -
« Reply #4 on: 30 Dec 2009, 05:20 pm »
For me 211s and GM 70.
charles
Triode Pete
  • www.TriodeWireLabs.com
    • Triode Wire Labs - Affordable Audiophile Cables
« Reply #5 on: 31 Dec 2009, 08:14 pm »
Western Electric 300B ... 40,000 hr. tube life. You get what you pay for.
Listens2tubes
« Reply #6 on: 31 Dec 2009, 11:31 pm »
Like AudioSoul I think it depends on many things. Amp design is high on my list. Consider how many Dynaco St-70 amps are still found with the original Mullard EL34 tubes playing sweet music. Not to meantion those GZ34 Mullards even with big voltage swings. :thumb:
« Reply #7 on: 31 Dec 2009, 11:51 pm »
Iam surprised no one know the exect amout of hour his tubes last.
In the 90 years a late friend had a Dynaco ST70 driving a JBL L90 which one or more EL34 last just six month, he used it on his CD shop.
