0 Members and 1 Guest are viewing this topic. Read 3998 times.
I have a new audio interface for home recording. I need a set of headphones to plug into this unit. Wondering about the Sennheiser HD200 for this - will only use it for the home recording and possibly work, not my home system.Here are the specs for headphone outHeadphone Outputs at Maximum Volume into 32 ohm LoadFrequency Response +/- 0.1dB, 20Hz to 22kHzSignal-to-Noise Ratio -108dB (A-weighted)Dynamic Range 108dB (A-weighted)THD+Noise 0.003% (-90.0dB), 1kHz, -1dBFSMax Output Level into 32 ohms +2.9dBV, typicalPower into Ohms 60 mW into 32 ohmsOutput Impedance 75 ohmLoad Impedance 24 to 600 ohmsCrosstalk <-75dB @ 1kHzI prefer closed since it is recording, and may use it at work also.Anyone?
