0 Members and 1 Guest are viewing this topic. Read 2565 times.
Maybe I'm missing something? It seems like everything with a pre-amp in it (stand alone, integrateds, receivers) have tape loops. Why? I'm pretty sure 99% of people haven't recorded anything onto cassette tape for close to a decade now.I think some people used the tape loop to connect equalizers. But wouldn't they be better between the pre and power amp?Wouldn't eliminating the tape loop cut costs and possibly make the gear sound better by not having extra stuff along the signal path?Maybe I'm asking the wrong question. A better question would be what are tape loops commonly used for nowadays?
Quote from: Stu Pitt on 20 Dec 2009, 04:48 pmMaybe I'm missing something? It seems like everything with a pre-amp in it (stand alone, integrateds, receivers) have tape loops. Why? I'm pretty sure 99% of people haven't recorded anything onto cassette tape for close to a decade now.I think some people used the tape loop to connect equalizers. But wouldn't they be better between the pre and power amp?Wouldn't eliminating the tape loop cut costs and possibly make the gear sound better by not having extra stuff along the signal path?Maybe I'm asking the wrong question. A better question would be what are tape loops commonly used for nowadays?i wouldn't consider a preamp w/o a tape loop. i like to run my dbx 3bx dynamic range expander. sometimes. i don't want it in the signal path when i am not using it. others feel the same way w/other outboard processors. your example of an eq is similar - if you don't always want it in the signal path, you don't want it between amp & preamp. better to have it in the tape loop than disengaging it at the eq.ymmv,doug s.
yes a tape mon and a mono switch too
