BRAND NEW OC9 ML/III SERIES 3
0 Members and 1 Guest are viewing this topic. Read 1100 times.
rayr0683
« on: 20 Dec 2009, 01:42 pm »
Hello,
       Anyone seen or heard the new version of the AT-OC9  ML/III???  It has a less aggressive stylus tip supposedly, back to Fine Line. With some other changes.
http://cgi.ebay.co.uk/audio-technica-AT-OC9-III-MC-Cartridge_W0QQitemZ200398047861QQcmdZViewItemQQptZTurntable_Parts_Accessories?hash=item2ea8a78a75
This looks like the official AT Japan Web Page
http://www.audio-technica.co.j.....oc9_3.html
Any one able to translate from Japanese
This is a Translator Tool output of the main text.
● Soriddoboronkanchireba φ0.26 special needle and line contact. Reads the inscription records all over the analog music signal.
● Pamenjuruyoku neodymium magnet and magnetic energy increased dramatically. Further strengthening of the central magnetic field coil cap, high-quality playback 行Naemasu.
● coils, terminal pins PCOCC adopted. PCOCC (high-purity oxygen-free copper single crystal-like) taste not sloppy, and allow pure transmission.
● Separation high Dyuarumubingukoiru wide response. L, R will be independent of each generation, to improve the separation characteristics.
● VC mold reduce unwanted vibration. High strength rigid plastic containing a combination of potassium titanate, achieve high oxidation.
● strong commitment to robust design of rigid body. Reducing parasitic resonance in aluminum-based rigid plastic, clear sound to play.
● Preparative high-quality brass screw with Ri. Matching the best in mind, adopting a brass screw.
                        Ray
