Standman stands handcrafted in the USA
0 Members and 1 Guest are viewing this topic. Read 2509 times.
standman
    • www.standmanstands.com
« on: 19 Dec 2009, 07:36 pm »
Up for your consideration is this custom audio rack by Standman for $479.00.Also available is the 19 inches wide by 16 inches deep coridinated amp stands at $229.00 as shown. Truly hand crafted representing a true value in as is stock form, or the many custom options in woods, finishes as well as sizes, spacing and number of shelves. Solid 1 1/2 inch thick by 6 inch wide Maple construcion with 3/4 inch industrial coated MDF shelves assembled with 1/4 inch by 5 inch Torx lags.This stand is very rigid, offers 8 inch shelf spacing standard and adjustable carpet piercing spikes.Shelves measure 22 inches wide by 17 1/2 inches deep. This is a very high mass stand and its weight represents this. Please feel free to enquire about the many options, colors and sizes that may fit your needs at 1-605-350-5619, I would be happy to discuss this with you.
bigjppop
Re: Standman stands handcrafted in the USA
« Reply #1 on: 19 Dec 2009, 10:10 pm »
Standman:
Tried to email at the address you have in your sig and it was returned as "undeliverable."  Is there a better address to get you at?
Goosepond
  • Virna!
« Reply #2 on: 20 Dec 2009, 02:05 am »
The last time Jeff emailed me (back in June) this was the email address he used:
[email protected]
Gene
standman
« Reply #3 on: 20 Dec 2009, 10:43 pm »
Hello, Either email address works.  There was an error in one address that has been corrected. Thanks,  Jeff
standman
« Reply #4 on: 27 Dec 2009, 08:19 pm »
To help better serve you a start to a very basic web sight can be viewed.   Thanks Standman stands.
standman
« Reply #5 on: 7 Feb 2010, 05:50 pm »
Color charts are available to choose shelf colors from.
standman
« Reply #6 on: 31 Mar 2010, 02:14 am »
Inquire about custom designing your complete audio furniture set.
nunhgrader
« Reply #7 on: 1 Apr 2010, 01:58 am »
Ferrari Red  looks awesome!
standman
« Reply #8 on: 9 Apr 2010, 01:55 am »
  Thanks for the compliment!  Want one?
