B60 load impedance
0 Members and 1 Guest are viewing this topic. Read 1059 times.
templetune
B60 load impedance
« on: 19 Dec 2009, 05:48 am »
Hello James
I can't find these specifications anywhere: what is the output impedance and minimum load impedance at the tape output of the B60 amplifier? Can you help? Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
Re: B60 load impedance
« Reply #1 on: 19 Dec 2009, 11:25 am »
Hello James
Hi Templetune - not sure on that one either - I will check with engineering.
james
