Universal Player(s) and switching between them
0 Members and 1 Guest are viewing this topic. Read 1895 times.
Dokter_doug
« on: 18 Jan 2004, 12:55 am »
Does anyone know of a switching device that would allow me to plug in both a multichannel DVD-Audio player and a multichannel SACD player (analog inputs) and then choose which set of signals I send to my pre-pro, which has only a single set of mutichannel analog inputs?
JoshK
« Reply #1 on: 18 Jan 2004, 01:55 am »
You need a MC input switch.  I don't know who makes a good one.  I remember I think I saw one on audiogon once.  Wasn't cheap.  I think I would make my own using a multi throw switch.  If you aren't sure how you would do that then you might ask on avsforum.com for an off the shelf product.
Rob Babcock
« Reply #2 on: 18 Jan 2004, 02:10 am »
By reputation, I think this is a good unit: http://www.zektor.com/mas3/index.htm
Haven't actually tried it myself, though.
Marbles
« Reply #3 on: 18 Jan 2004, 03:21 am »
Sony has a discontinued pre that sells used for under $500 (that was the new price I beleive) that was supposed to be perfect for that solution and was rated as  stereophile class A.
If you wanted to go cheap, go down to radio shack and get a couple of AV  switches.  These are the red/white/yellow A/B switches.  Since each has 2 channels of 3 switches, you need two.  Very slick, very cheap.  Don't know how well they pass the audio though.
Rob Babcock
« Reply #4 on: 18 Jan 2004, 05:39 am »
I can't recall the model #, but that Sony pre is getting really hard to find, I think.  I haven't seen one for sale in quite awhile.  Onecall.com used to carry it...
michael w
« Reply #5 on: 20 Jan 2004, 03:00 am »
Sony TA-P9000ES is the model.
Two 5.1 analog inputs, 5.1 and 2 ch bypass, full remote control.
When first released they were the only game in town and everyone was after one, especially Sony TA-E9000ES preamp users. Now with other MC analog preamps available the Sonys aren't that hard to find.
There's one on Audiogon now
http://cgi.audiogon.com/cgi-bin/cl.pl?preatran&1079662363
cheers,
flintstone
Switch-box
« Reply #6 on: 22 Jan 2004, 01:28 pm »
This could work for you: http://home.comcast.net/~shawnfogg/
Dave
Dokter_doug
« Reply #7 on: 22 Jan 2004, 03:10 pm »
Thanks folks. Lots of good suggestions. I particularly like the "Switchbox" option as it won't break the bank.
JoshK
« Reply #8 on: 22 Jan 2004, 03:32 pm »
another switcher, although more expensive provides 3 in 1 out.
zektor ma3
