0 Members and 1 Guest are viewing this topic. Read 4385 times.
I have the same exact table, but do not have clearance problems. My arm and cartridges are different, so comparing dimensions on these should illuminate where his problems lie.Here are my observations:* from the photo above, it appears I have the identical armboard as the Pig man. That means identical thickness.* his circular tonearm mounting plate is 1/8 inch thick; mine is 3/4 inch. Mine is 5/8 inch thicker, so all other things equal, this makes the rear of his arm lower than mine by that same amount.* all my cartridges are 19 mm high (stylus to top of cartridge body) as compared to 9mm for Senor Pig. That will make the front of his arm about 3/8 inch lower than mine. In summary, his root problem is that the arm's rear is too high relative to the front. The rear and the front of his arm are lower than mine, with his rear dropping more than the front by 1/4 inch. If anything, this relative difference should help his clearance issue!But it does not, so the logical conclusion must be that compared to my arm, his arm tube starts much higher up on the arm pillar. One other note, I raise the rear of my arm about 3mm (for all cartridges) to get the correct VTA.I think at the end of the day, if you don't wanna mess around with mats and shims, you will need to go to a taller cartridge. It is the most direct and least kludgey solution. I bet one in the 19mm range would do the trick. See if you can borrow one to make sure it works before committing $$. Tough dilemma. Good Luck!~ John
.........This is quite a nice turntable, especially for the modest amount of cash that I have into it.
There is a set screw adjustment for that. Look closer.Wayner
I also raked the position of the ramp inwards, so that the tonearm in still on the portion that is level and does not rise, when it approaches the end of the record. The Rega cue ramp is not perfectly level, but has a slight rise at the end of it.
