Connect icon to active subwoofer
0 Members and 1 Guest are viewing this topic. Read 1832 times.
bjoern
« on: 16 Dec 2009, 01:38 pm »
Is it ok to connect the Icon speaker output using the RJ45-banana to an active subwoofers high level input?
This way I can use the wires included with the Icon and then "normal" cables from the subwoofers "speaker out" to the main speakers.
Or - must I use the line out on the Icon for the subwoofer?
/Bjoern
nuforce-casey
Re: Connect icon to active subwoofer
« Reply #1 on: 16 Dec 2009, 09:16 pm »
Hi,
No, the RJ45 must not be grounded.   I would suggest not to.
