Room Analysis Using a Mac
0 Members and 1 Guest are viewing this topic. Read 10872 times.
Ernest
« on: 15 Dec 2009, 03:44 am »
I'm getting a room in my basement set up as an audio room and would like to try out doing room analysis, which I've never done before.  Are there any good options for doing this with a Mac (laptop)?
Ernest
Rocket_Ronny
    • ScriptureSongs.com
Re: Room Analysis Using a Mac
« Reply #1 on: 15 Dec 2009, 03:54 am »
This is what pro's use. http://www.mhlabs.com/metric_halo/products/foo/
Might be over the top however.
Rocket_Ronny
Ernest
« Reply #2 on: 15 Dec 2009, 04:02 am »
Wow, that's actually scary looking!   :o
Also, unfortunately, way beyond my price range.
Ernest
audioferret
« Reply #3 on: 15 Dec 2009, 04:31 am »
I have this and used it with a Duet; I have not mastered it, but you may see if Ethan Winer can help: http://www.realtraps.com/articles.htm
Fuzzmeasure: $150.00
http://supermegaultragroovy.com/products/FuzzMeasure/
Apogee Duet: (Or the Solo)
http://www.apogeedigital.com/products/duet.php
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #4 on: 15 Dec 2009, 07:56 am »
I'm a happy FuzzMeasure user... i use it with an Edirol FA66.
dave
oneinthepipe
  • Trainee
    • Salk Signature Sound/Audio by Van Alstine two-channel system
« Reply #5 on: 15 Dec 2009, 03:17 pm »
You can start with Room EQ Wizard, which is available free.
http://www.hometheatershack.com/roomeq/
All you need for some basic measurements is a Mac, a mic, a phantom power supply and a couple of cables to connect the mic, power supply, and Mac.  On Ethan's site, he indicated that Behringer ECM8000 is a decent inexpensive mic (approx $50.00).   Cross Spectrum Labs has had some group buys on calibrated Dayton and Behringer mics on hometheatershack.  They also have a sale on calibrated Dayton mics on their site.
http://www.cross-spectrum.com/measurement/calibrated_dayton.html
A Behringer phantom power supply is available for $19.95 from Amazon and others. The cables can be purchased at a variety of sellers, but monoprice has particularly inexpensive cables.
For about $100.00, you can get a calibrated mic, a phantom power supply, and cables, and the software is free.  If you don't need a calibrated mic, the cost can be less.
TomS
« Reply #6 on: 15 Dec 2009, 03:29 pm »
I had a lot of problems getting REW to work on my Macbook and gave up, but maybe someone has worked out the kinks since then.
jtwrace
    • TIPP YouTube Channel
« Reply #7 on: 15 Dec 2009, 03:30 pm »
The only thing I caution you about REW is the setup.  It's not hard once you've completed it but if you have no patience, you will not enjoy yourself.  The online help at hometheatershack.com is great though.
TomS
« Reply #8 on: 15 Dec 2009, 04:31 pm »
Yep, no problems with the Windows version...
oneinthepipe
  • Trainee
« Reply #9 on: 15 Dec 2009, 07:30 pm »
Since he has a Mac, he can run REW under Windows, too (assuming he has a Windows disk).   :D
low.pfile
« Reply #10 on: 15 Dec 2009, 08:14 pm »
I tried REW with Mac OS (nope don't have a Win disk) and gave up. tried a few different times. couldn't get the soundcard (macbook pro intel) calibrated properly. still a slightly bit curious about my room though.
@ oneinthepipe: I reread the REW setup instruction PDF and don't see a mention of "a phantom power supply" where is that used?
oneinthepipe
  • Trainee
« Reply #11 on: 15 Dec 2009, 10:46 pm »
What were you using for a microphone?
If you use the Behringer ECM8000 or a similar mic, the mic needs a power source.  Behringer makes an inexpensive phantom power supply.
http://www.amazon.com/Behringer-PS400-Ultra-Compact-Phantom-Supply/dp/B000FG795I/ref=sr_1_1?ie=UTF8&s=electronics&qid=1260917151&sr=8-1
low.pfile
« Reply #12 on: 15 Dec 2009, 11:26 pm »
Ah, I see the PS is for the mic.....
I used what was being recommended on that site back then: Galaxy CM-140 Check Mate SPL Meter
maybe that has changed I will look at that forum over the holiday break.
Ernest
« Reply #13 on: 19 Dec 2009, 01:18 am »
Thanks for the info on REW.  I'll check it out.
-E
george_k
« Reply #14 on: 25 Jan 2010, 09:38 pm »
Interesting, but how do you connect the mic to your Mac? Do you need another box?
bpape
    • Sensible Sound Solutions
« Reply #15 on: 25 Jan 2010, 10:07 pm »
You'd need a DA box to convert pro level balanced to consumer level unbalanced.
Bryan
TomS
« Reply #16 on: 25 Jan 2010, 10:15 pm »
I just use the M-Audio MobilePre USB that has power supply built-in  http://www.m-audio.com/products/en_us/MobilePreUSB.html
REW forum on hometheatershack has lots of info and faq's on this stuff.
