Carver PRO Amps
0 Members and 2 Guests are viewing this topic. Read 2842 times.
8thnerve
Carver PRO Amps
« on: 17 Jan 2004, 03:44 pm »
I have a bit of overstock on these units finally, and I don't like inventory, so here is what's available:
Carver PRO ZR1600 NEW IN BOX - Unmodded, unopened. - $800
(I can mod this unit for an additional $300 if interested)
Carver PRO ZR1000 Modded, mint, 200 hours. x2 - $1000 each.
(these two units have been burning in since modification in the same spot.  absolutely mint.)
8thnerve
ZR1000 package deal
« Reply #1 on: 19 Jan 2004, 06:14 pm »
I will sell both the ZR1000s and will ship them in Monoblock configuration for a total of $1699.  That is 875 Watts into 8 ohms, and 1000 Watts into 4 ohms.  These units are both Eighth Nerve modified.  They can ship immediately.
8thnerve
Carver PRO Amps
« Reply #2 on: 29 Jan 2004, 12:06 am »
New deal on the ZR1000s.  I will sell the pair, modded, set in mono mode (can be switched to stereo mode with a simple cable swap, anyone can do it) with 2 custom Eighth Nerve Spinal Cords - Amp version that are about 4 feet long with the ground lifted.  I made these specifically for these amps.  The power cords are $179 retail a piece.  The total retail on this system is $3056.  Yours for $1599!  Ready to ship.
PeteG
Carver PRO Amps
« Reply #3 on: 29 Jan 2004, 01:21 am »
That's a very good deal, Nathan. :o
Does the spinal cords with the lifted ground make a big difference.
8thnerve
Carver PRO Amps
« Reply #4 on: 29 Jan 2004, 02:30 pm »
Quote from: PeteG
Yes it does, especially with the Carver amps.  One of the things that is usually a problem with any budget amp is the accuracy of the torroidal winding.  This generally causes a ground loop somewhere, so lifting the ground onthis amp makes it MUCH quieter.  I wouldn't use the amp without one.
8thnerve
Carver PRO Amps
« Reply #5 on: 2 Feb 2004, 11:40 pm »
I sold one of the 1000s so there is one available in stereo for $850 including the power cord.  This is a new 8th Nerve modded ZR1000 with Eighth Nerve Spinal Cord Amp version.  Retail is over $1500.
