For sale: Sanders Sound Sytems ESL Amp - SOLD
0 Members and 1 Guest are viewing this topic. Read 1590 times.
RPM123
« on: 13 Dec 2009, 08:15 pm »
Downsizing, therefore, Selling my approximately 2 year old Sanders Sound Systems ESL amp. It is in great condition and will drive loads down to one ohm!  RCA and XLR inputs. Will handle electrostats, planars and cone speakers with ease, plus it carries a LIFETIME TRANSFERABLE WARRANTY! Stock fuses replaced with over $150.00 worth of Furutech fuses. Very "neutral" and does not sound like a sand amp. Also, very efficient and runs cool. Check out Roger Sanders White Paper on amps.
$2100 and will cover shipping to lower 48 states at this price. Pay Pal add 3%. SOLD!
Specs:
 Power (Stereo Version)
  360 watts RMS per channel into an 8 ohm load
  600 watts RMS per channel into a 4ohm load
  Power (Monoblock Version)  1000 watts RMS into an 8 ohm load
 1600 watts RMS into a 4 ohm load
 Bandwidth DC through 100kHz
 Slew Rate 500 volts/microsecond
 Input voltage required for full output 2 Volts
 Input Impedance  50kohm (both balanced and unbalanced)
 Gain 26dB
 Noise  More than 110dB below rated output
 Damping Factor Greater than 600 into an 8 ohm load
 THD Less than 0.005%, 20 Hz - 20 KHz
 IMD     Less than 0.004%, 20 Hz - 20 KHz
 Dimensions 17" wide x 5.5" tall x 16" deep (43cm x 14cm x 40.6cm)
 Weight 54 pounds  (24.5 Kgs)
« Last Edit: 23 Dec 2009, 05:36 am by RPM123 »
