Open Baffle Shoot Out?
0 Members and 1 Guest are viewing this topic. Read 3281 times.
Bear
« on: 12 Dec 2009, 05:17 pm »
 :idea:  open baffle shoot-out 2010.  Linkwitz Orion++ vs. GR-Research Super V. vs. Salk Sound Archos.    just thought this would be an interesting match up if someone could pull it together.
sfdoddsy
Re: Open Baffle Shoot Out?
« Reply #1 on: 14 Dec 2009, 11:36 pm »
It would indeed.
Good luck with it.
doak
« Reply #2 on: 15 Dec 2009, 02:33 am »
How about adding a pair of Hawthorne Audio Sterling Trios to the mix to make things even more interesting???
 aa
kristian85
« Reply #3 on: 24 Dec 2009, 05:18 pm »
A fine idea, but it wouldn't be a fair fight; the Orions are inherently superior by virtue of being active. There are too many things an active speaker does correctly that a passive system cannot hope to do.
Is anyone running the GRs active, say with a Marchand electronic crossover?
Best,
Kristian
doak
« Reply #4 on: 24 Dec 2009, 05:52 pm »
Best,
Kristian
I use an electronic crossover with my Hawthorne Trios and a separate amp to drive the four Augie bass drivers.  The crossover from cone to compression driver for the Sterling Iris full-range is of superior quality - Mundorf SIO, Solen copper foil coils and a Mundorf resistor.  I am also doing a passive high pass to that driver @ 110Hz that is accomplished with one Vishay nude resistor and one Mundorff SIO cap. The resulting sound speaks for itself.
Doak
« Last Edit: 24 Dec 2009, 07:26 pm by doak »
