Ipods?
0 Members and 1 Guest are viewing this topic. Read 1259 times.
chgolatin2
Ipods?
« on: 12 Dec 2009, 12:07 am »
I have a total of 4 ipods, one of them being an Iphone.  How can I integrate all of them with itunes?  Also, does itunes have a setting for mp3?  I went to the preference tab and I couldn't find it.  Well, I'm not a computer geek and I dont know much about Itunes so I need some help  :scratch:
Also, is their any freeware that I could download to remove all of my mp3's from the ipods and put them on a separate folder?  Hmmmm...
Thanks to all in advance
Crimson
Re: Ipods?
« Reply #1 on: 12 Dec 2009, 10:45 am »
Not sure what you mean when you say you want to integrate them with iTunes. You can either have all four contain the same content by syncing to the same playlist, or have have each one contain different content by syncing to different playlists.
As for MP3, yes, iTunes does MP3. For ripping discs to MP3 go to Preferences > Import settings and select MP3 Encoder.
A quick google search will give you a plethora of free apps that allow you to siphon off the content of your iPod to your computer. I don't have any particular recommendations.
chgolatin2
Re: Ipods?
« Reply #2 on: 12 Dec 2009, 03:28 pm »
Dunno, I was informed that I could even sync none ipods with itunes but I havent been able to do so, also how can I just sync all of them to itunes?  It gives me an error telling me that the user is not authorize to use this computer :scratch:
