Here's a head scratcher...
0 Members and 1 Guest are viewing this topic. Read 1260 times.
JakeJ
« on: 10 Dec 2009, 12:59 am »
Today my Piccolo developed noise in the left channel.  It is a crunchy, spitty, hissy combination of sounds.  It is constant and it does not get louder when I change gain.  Also I tried all load settings and it remains unchanged.
 :banghead:
Opened it up but saw no obvious problems.  :sad:
Anyone got any suggestions?  :dunno:
TIA,
Jake
hagtech
Re: Here's a head scratcher...
« Reply #1 on: 10 Dec 2009, 02:58 am »
Broken interconnect.
jh
JakeJ
« Reply #2 on: 10 Dec 2009, 11:52 am »
Ah, thanks Jim.  I had taken my Piccolo over to a friends for him to try out and see if he want to use one in his system.  I know we didn't use any other interconnects so that may be the culprit.
Will do some testing and report back.
Jake
BobM
« Reply #3 on: 10 Dec 2009, 12:59 pm »
I found a similar problem with a friends Piccolo. Those RCA jacks take a lot of abuse, and they are only held by the solder on the board. Try flowing a good amount of solder over their connections and it should help hold them to the board a little better and make the connections more firm.
