0 Members and 1 Guest are viewing this topic. Read 6911 times.
If the driver is sealed in it's own capsule, you may use most any box.Most Midrange and Low frequency drivers have an open basket that allows air movement to the rear.The damping of this "back wave" is part of the art in loudspeaker design.While you may have some lucky accidents by mixing and matching, staying with an established (and tested) design will provide simpler positive results. There are some VERY interesting designs on the Linkwitz site, and my favorite, Zaph Audio.http://www.zaphaudio.com/
If you're looking for a kit, GR Research... http://www.gr-research.com/ offers a variety of kits that are outstanding by any standard.http://www.gedlee.com/ ...is also worth checking out.
My question is can I use these drivers and crossovers in any enclosure or does crossover design/specification depend on the cabinet?
Don't forget Parts Express and Madisound if you want diy speakers or kits. Howard ps: It can become addictive!
but these guys go beyond "pretty good".
Those ScanSpeak drivers seem a little bit pricey, does anyone know of floorstanding designs using Fostex drivers that are similar to the SP95s?Kanimambo,-A
