**SALE PENDING** Blue Circle BC86 Power Line Pillow
0 Members and 1 Guest are viewing this topic. Read 6099 times.
Big Red Machine
Ran out of outlets in my room to use this.
$95 shipped CONUS.  How about $75?
« Last Edit: 29 Jan 2010, 12:51 pm by Big Red Machine »
Big Red Machine
Re: Blue Circle BC86 Power Line Pillow
« Reply #1 on: 8 Dec 2009, 12:26 pm »
bump
Big Red Machine
« Reply #2 on: 11 Dec 2009, 01:16 am »
bump
Big Red Machine
« Reply #3 on: 14 Dec 2009, 03:58 pm »
lowered price
Big Red Machine
« Reply #4 on: 15 Dec 2009, 01:39 pm »
Another great stocking stuffer.
Big Red Machine
« Reply #5 on: 17 Dec 2009, 06:55 pm »
Stuff that stocking for your loved one!!
Big Red Machine
« Reply #6 on: 21 Dec 2009, 06:07 pm »
bump
decal
« Reply #7 on: 21 Dec 2009, 07:43 pm »
Red,you might get some offers if you would post some info on the thing.Just a thought.
ecramer
« Reply #8 on: 21 Dec 2009, 09:24 pm »
I have one of these in my system  :thumb: works great   don't have a clue what inside it but its a nice tweek at the asking price
ED
oh yea bump
Big Red Machine
« Reply #9 on: 21 Dec 2009, 10:15 pm »
Mine doesn't say what version so let's assume it is not an MKIII:
BC86 provides a convenient and effective solution for the reduction or elimination of power line noise. Simply plug the BC86 into a duplex receptacle or spare outlet on a power bar and it dramatically reduces unwanted powerline noise present at the outlet. The effect extends to receptacles, on the same circuit, up to 20 ft. from the treated receptacle.
The Mark III...
The original BC86 and the MKII had one slight drawback.  Occasionally a GFI would "see" them as a ground fault.  Fortunately this happened very rarely but the fact that it happened at all indicated that there was a problem that needed addressing.
Well, we solved the problem and improved the filtering at the same time.  The MKIII has double the filtering, and no printed circuit board - all hardwired.
Listen to our sample video (2Mb).
The noise you hear is the noise present in the powerline amplified by the device on the left of the screen.  When the BC86 is plugged into the line the reduction in noise is readily apparent.
Technical Information
4 distinct wide 'Q' filters covering a wide range of frequencies.
fully enclosed in a steel chassis for RF rejection.
filtering is cumulative with the addition of one or more additional BC86s
MKII - broader range of filtration than the original BC86
MKIII - eliminated PC board - hard wired - double the filtration of the MKII.
Big Red Machine
« Reply #10 on: 1 Jan 2010, 02:29 pm »
bump
Big Red Machine
« Reply #11 on: 7 Jan 2010, 01:15 pm »
bump
Big Red Machine
« Reply #12 on: 17 Jan 2010, 03:27 pm »
bump
cliffy
« Reply #13 on: 25 Jan 2010, 04:32 pm »
Do you have the serial number?  Blue Circle can check there records and provide the revision number.
Big Red Machine
« Reply #14 on: 25 Jan 2010, 11:17 pm »
Handwritten and hard to decipher.  Maybe it is:
86PPEM PPPA
Big Red Machine
« Reply #15 on: 25 Jan 2010, 11:54 pm »
Hello
This is the original version built in Feb 2000.
Regards
Mark
