0 Members and 1 Guest are viewing this topic. Read 7875 times.
If you have nothing on the outside, you may have to open the box and see if you can see any spec on the motor. I suspect it's a DC motor and you need to know the voltage for sure and minimum current requirement if possible. Then you can pick up something like this to power the motor. Good luck.
Wow is right. DC motor with unstable voltage means wow and flutter -- good for special effects if you are looking for that. I wouldn't trust a cheap switching PS for turntables.
To get the motor "running", would I be able to use a wall wart though, and then get a motor controller afterward? Right now, I just want to know if I'll be able to use this motor, or if I'm looking at getting an entirely new motor altogether.
Quote from: LordCloud on 9 Dec 2009, 05:44 pmTo get the motor "running", would I be able to use a wall wart though, and then get a motor controller afterward? Right now, I just want to know if I'll be able to use this motor, or if I'm looking at getting an entirely new motor altogether.i suspect you could get it running w/a simple small 9v battery, if you were yust wanting to see if the motor works. i would suspect that motor is dc not ac, and i don't see this hurting the motor regardless of its woltage. then, yes, you could get a p/s like what rim suggested, (i use a similar p/s on my oracle's origin-live dc motor. you wouldn't even need to know the exact woltage on the motor, w/adjustability of 0-40v like that p/s has, you could simply set the proper woltage w/the aid of a strobe disc & light. by simple wirtue of getting the platter to spin at the proper speed, you will be getting wery close to the proper woltage of the motor, if not dead-on. these lab-grade dc p/s's are fantastic. a great cheap upgrade to most any application calling for dc woltage, imo. i got rim his first one in exchange for him giving me cabinets and helping me to ship them w/an vmps rm40 kit i was selling. (if the motor turned out to be ac, i would attempt to start it only w/a wariac, and starting at wery low woltage -from 0v and working your way slowly up. but, certainly test w/dcv first, if you don't know what it is.) doug s.
if that motor came from that deck, it is a sota, for sure; and you can query them about its woltage. doug s.
More reading has produced more questions. Since the motor has trimpot adjustments for speed already, does that mean I don't require a "power supply" but simply a means of power delivery? Do the trimpots already vary the voltage?Another question. Would I be able to use something like this? http://www.sears.com/shc/s/p_10153_12605_02871486000P?vName=Automotive&cName=Batteries+%26+Chargers&sName=Battery+Chargers+%26+Boosters#reviewsWrapGalibier turntable motors are similar to mine in that they have trim pots to adjust the two speeds and the battery power supply is one that they recommend. If that would work, that would be even better as it's inexpensive and easy to obtain.http://www.galibierdesign.com/prd_motor.html
