0 Members and 1 Guest are viewing this topic. Read 8098 times.
I got to thinking about this some more and was wondering if I could incorporate a small stepdown of voltage... My house runs 125V and most gear specifies it's operation around 118. I know there's a little variance but, I'd rather run the gear as close to what it wants as possible. I know when I was building my amp, it was recommended that I use a 33-0-33 voltage configuration vs. the normal 35-0-35 to accomodate the higher voltage to provide 'optimum' results. So, I'm wondering if the same holds true ...
Is there a modern day equivalent?
Do you mean something like this?:http://used-line.com/cgi-bin/used/~4452451_/Variac_W10MT3.htmIs there a modern day equivalent?...edit......I found a bunch on Ebay from Staco and some other brands... I think this would be great if you were demo'ing equipment and needed to change the voltage from place to place.... But, I would rather build something that isn't variable and it is corrected for the voltage I have now... cleans the power, and that has 6 outlets all in one unit.
