Bent Audio TVC Matching
0 Members and 1 Guest are viewing this topic. Read 2296 times.
Doc Jr 8156
« on: 14 Jan 2004, 09:19 pm »
Hi John,
I'm trying to figure out if I will have a problem with the ff. setup:
Cornet Phonostage (with 44db gain plus 16db from step-up) w/ an output impedance of 1 Kohm------->Bent Audio-------> Odyssey Stratos amps with 10 Kohm input impedance.  What do you think?  Thanks.
Marbles
Re: Bent Audio TVC Matching
« Reply #1 on: 14 Jan 2004, 10:27 pm »
Quote from: Doc Jr 8156
Hi John,
Doc, I'm running a Cornet with the TX103 step ups into a Bent TVC to Symphonic Line Kraft mono 400's (Biggest brothers of the Stratos amps from the same lineage, and the same 10 KOhm input rating) and love it.
I have absolutely no problems.
Doc Jr 8156
« Reply #2 on: 14 Jan 2004, 10:30 pm »
Marbles,
Thanks for the info.  If everything falls through my set-up will be the small brother of your set-up.  Teres TT---Cornet----Bent------Odyssey.
Marbles
« Reply #3 on: 15 Jan 2004, 01:52 am »
Marbles,
Sounds like your going to have a kickass system there.
FYI, I got my tonearm from 2Juki on audiogon and a rebuilt cartridge from Klaus.
Both are highly recommended sources for gear.
