N3 vs N3s sound?
0 Members and 1 Guest are viewing this topic. Read 2212 times.
Lightspeed66
N3 vs N3s sound?
« on: 2 Dec 2009, 04:12 pm »
The N3s is a sealed version of the N3 is it not? If so, can anyone give a description of the sound differences? Bass response?
Jeff
Danny Richie
Re: N3 vs N3s sound?
« Reply #1 on: 2 Dec 2009, 07:45 pm »
They are basically the same speaker, same drivers, same crossover. What is different is the way the drivers are loaded and the bass response. The floor standing version uses a transmission line design that allows for a lower -3db at 40Hz bottom end.
Lightspeed66
« Reply #2 on: 2 Dec 2009, 09:44 pm »
Oh! So the N3s is not floor standing. But meant to sit on a stand?  How low does the sealed version go?
(yes, that was my email BTW)
Danny Richie
« Reply #3 on: 2 Dec 2009, 09:51 pm »
It can be used on a stand or layed on its side as a center channel. It will hit -3db's around 80Hz.
Box plans are here: http://www.gr-research.com/pdf/av3sbox.pdf
scc135
« Reply #4 on: 16 Dec 2009, 03:19 pm »
Hey Danny, your pdf shows an AV3 center so I'm guessing you mean that the N3 can also be made with a similar center enclosure (with dimensions modified for larger tweeter)? Also, how many sheets of no-res would be needed?
Danny Richie
« Reply #5 on: 16 Dec 2009, 03:25 pm »
I meant to post this one: http://www.gr-research.com/pdf/Neo3S.pdf
One sheet of No Rez will do it with a little left over.
scc135
« Reply #6 on: 16 Dec 2009, 08:23 pm »
on the brace, is the cut half circle in the front or back?
Danny Richie
« Reply #7 on: 16 Dec 2009, 09:12 pm »
The half cut circle is at the front.
